Question about DIGITECH VOCALIST LIVE 2
My digitech vocalist 2 is extemely noisy! the ground switch helps only partly. It seems to be bad when you first turn it on and gets worse the longer you use it.
  • DIGITECH Master
  • 5,603 Answers
To check for a temperature related problem, try putting it in the freezer for a while then bring it out and see if it affects the noise. If it does, then problem can be found with circuit cooler mist.
Also see if noise is affected by vibration.
Posted on Sep 10, 2009
Can i run Vocalist live 3 through only an amp? if so how what cables do i need.?
The only guitar amp that has 2 female jacks, one xlr and one 1/4" is a tall Acoustisonic anp by Fender . I have one and I use the Vocalist 3 and I still have an instrument jack for my acoustic guitar . hope this helps .
Sep 18, 2012 | Digi-Tech Digitech Vocalist Live 4...
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
Jun 21, 2012 | DIGITECH VOCALIST LIVE 2
My digitech looper phrase sampler will not turn on
A common problem is that somebody has paired the WRONG power adapter to this unit.
The REQUIRED adapter should be 9VAC (not DC) at 1300ma or 1.3 amps.
Note that UNIVERSAL replacement adapters will NOT work with the Vocalist.
Feb 06, 2011 | Digi-Tech Digitech Vocalist Live 4...
How do you hookup a digitech vocalist performer to a pa board
What mixer will you be using it with and how many channels will you need to use it on. After I know this info I can help you.
Thanks
Jan 16, 2011 | Digi-Tech Digitech Vocalist Live 4...
Vocalist live 2 problem. power to unit OK , lights up. Guitar output OK. No tuner, no vocal output.
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
Jan 13, 2011 | DIGITECH VOCALIST LIVE 2
I was using my digitech vocalist live 2 pedal during a gig 3 days ago and about 2 songs in, everytime i touched any part of the pedal or pressed the harmony on/off switch to activate the harmonys, the...
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
Dec 28, 2010 | DIGITECH VOCALIST LIVE 2
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
All the LED's come on and it does nothing
Have you seen this:http://www.digitech.com/products/Vocalist/Flash_Demo/VocalistLive2_Tutorial.php
Oct 15, 2009 | DIGITECH VOCALIST LIVE 2
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
hello,
can be too late but one never knows:
http://mesnotices.fr/314159.php?k=b7e42b97c5e87d24451de2516f66eef9&ID=18334&q=DIGITECH%20VALVEFX
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
DIGITECH VOCALIST LIVE 2 Logo
193 people viewed this question
Top DIGITECH Music Experts
steve cannon
Level 1 Expert
noel
noel
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
