Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
How to scan something in a printer to make more
How do you scan a document onto your computer
If your printer supports scanning, then the main issue you have is
software to control the printer and DO something with the document once it is scanned. Readiris is what I use. I have version 11 and I think they are up to 13, but it works GREAT. There probably are other pieces of software out there to handle scanning and result document manipulation. With Readiris, you can make the scanned item directly into a jpeg or a pdf. which is really useful. You might want to try download.com and search there. Good Luck
Mar 09, 2013 | Canon PIXMA MX340 Wireless Office...
Need to scan from computer to printer
Try searching Google for scanner software, there will be something out there to support your machine!
Sep 26, 2012 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
I have a HP PSC 2350 all-in-one printer. And I have VISTA. The printer aspect works fine because the technician who set up my satelite installed something to make it work (print only). However, I haven't...
Go to the Hp website and look for an updated printer driver for this printer that works with Windows 7 or Vista. If the printer is very old, an updated driver might not be available.
Jan 05, 2011 | HP PSC 2350 All-In-One InkJet Printer
Hi everytime I try to scan something my computer
Please follow the link to uninstall and reinstall the drivers for your device.
Installing Devices on PCs and Laptops
Mar 22, 2010 | Canon Pixma MP480 All-In-One InkJet...
How do I get my printer to scan a photo to my computer? When I push scan it does nothing, if i push copy it will print a copy. Is there something I am doing wrong?
Yes you are. Try opening your printer's application on your computer and from there order your printer to make a scan. It will ask you where do you want to save it. I think. If not there must be a dialog windows where to input these settings. Next time you're asking something try to be more specific. For example what type of printer we're talking about.. :)
Nov 21, 2009 | Lexmark X3350 All-In-One InkJet Printer
How doI scan something?
To scan something from your printer to the computer you should have the hp solution center installed in your computer double click and open the solution center place the document or the picture that you wnat to scan on the glass bed of the printer (the text content should face towards the glass)
now click on the scan document or scan picture button on the hp solution center a window will come up click n the scan button then a window will come up showing the preview of the scaned document or picture click finish to finsh the scan
now you can view your scan by going to the MY SCAN folder in MY DOCUMENTS
Jul 30, 2009 | HP OfficeJet J4580 All-In-One Laser...
Cant figure out how to scan something
You can start scanning a document two dfferent ways--from the printer or from your computer. With either method, the first thing you need to do is place whatever you want to scan face down on the glass of the printer. Close the top cover.
If you want to do everything from the printer, press the button with the diamond on it. "Save Photo" should appear on your computer. You can then choose a name for the file and a location where you want to save it.
To proceed from the computer instead, you can start the Lexmark Imaging Studio. Click "Scan," select the Document option, and then click "Start."
That should get you started!
Jan 19, 2009 | Lexmark X2500 All-In-One Printer
Hp 1350 printer will not scan.
You need sofrware that captures the scan from the scanner. usually comes with the printer, you have to opemn the program and tell it to scan and save.
Scanning by just placing a paper on the scanner and pressing the scan button just tells the printer to scan and probably print a copy, but it doesnt send it to the computer unless theres a program asking for it. Check the installation cd and go through the software that came with it.
Jan 30, 2008 | HP PSC 2355 All-In-One InkJet Printer
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
