Question about Dell A920 InkJet Printer
A920 doesn't turn on when plugged in to wall and usb to laptop. what could be the problem?
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
I get the blue screen with MSDC on it, it doesn't turn on unless plugged into the wall/electronic device, it wont turn off after I get the blue screen unless I unplug it, and it's been chargin
It is charging by USB port using ac adapter, can also charge by computer USB port during picture uploads and downloads. Do you need an instruction manual.
Feb 17, 2012 | Vivitar ViviCam 8025 Digital Camera
After charging my lindle on my laptop i cant switch it on
Try charging it with the electrical wall plug-in.
I read in some Kindle reviews on Amazon that charging through USB ports on a computer doesn't always work.
Did you get a green light that indicated the battery was fully charged?
Dec 26, 2011 | Amazon Kindle 1
How do i connect my toshiba laptop to the dell a920
First connect your printer to computer with usb cable. then download driver from below link. Click here Click on above link download driver for your os and install then restart printer and computer then you can use it. Let me know if you need further assistance. Thanks for using FixYa.
Aug 18, 2011 | Dell A920 InkJet Printer
I cant charge my ipod from laptop
It is possible that you may not have it plugged into a USB 2.0 slot. Try switching USB ports and see if that does anything. If not try a wall charger and if that doesn't fix it you may need to have your Ipod looked at. Let me know if this helps, Jeff from fixya
Jun 12, 2011 | Computers & Internet
Printer not connected to hp laptop
If this laptop and printer combination worked before, try a new cable. They often fail inside without any notable outer damage.
Sep 18, 2009 | Dell A920 InkJet Printer
Printer will not power up
Try to check your wall outlet using voltmeter/multimeter just to determine whether your wall outlet is without or have a supply..the voltmeter must read 110V or little bit higher...
May 18, 2009 | Dell A920 InkJet Printer
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
A920 Printer
Is the printer connected by USB cable? Turn on the printer, go to Start, Control Panel, System and look for the Device Manager button. There, you can see all the devices connected and if they are working or not. If the port where the peinter is connected say "working properly": delete all the jobs from the queu, uninstall the printer, disconnect it, turn off the computer and turn off the printer. After some minutes turn the computer on, plug the printer and install it again.
Aug 17, 2008 | Dell A920 InkJet Printer
A920
I've tried the same thing with my phone when i got it. This model phone came out right before it was possible to link the phone to the computer w/ the usb. The only thing the USB is good for is to plug into the printer and print off your pics. But there is a solution to this problem!!! Use your memory card in the SanDisk trans flash adapter. Just plug it into the computer and drag over the music you want onto it. Then in the phone you go to the music and the songs should appear. Hope this helps...
Dec 21, 2007 | Samsung MM-A920 Cellular Phone
Dell A920 InkJet Printer Logo
27 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
