Question about Refrigerators
Fridge won't make ice
Ice maker will not make ice.
  • 4,070 Answers
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Sep 09, 2009
Buzzing sound Kitchen Aid fridge Model KBLA20EMSS
It may be the arm in the ice maker is down. Even though the ice maker does not have the water hooked up if the arm above the ice bin is down it will still cycle the ice maker try lifting up the arm it should stay up this signals the ice maker that the bin is full and should shut off the ice maker. Hope this helps.
Dec 31, 2013 | KitchenAid KSCS25FKSS Side by Side...
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Whirlpool ice maker not working
Ice makers are some of the most worked part of a refrigerator and have about a five year lifespan. There are just too many things that can go wrong that can stop the ice making process. To explain the process of a Whirlpool ice maker I am going to post a Whirlpool Ice Maker Troubling pdf and a short YouTube Icemaker Repair toutorial. If you have any questions I will be here to assist you, Thanks Sea Breeze
May 23, 2012 | Whirlpool Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Ice maker not working. Water is going to fridge,
heatman101
68tj
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
