Question about Gateway MX3560 Notebook
I need to replace the keyboardon a Gateway MX3560. are there any case screws to take out? or just pop off the coverplate at the top of the keyboard?
    President:
  • 2,022 Answers
No there is two scerw in back side make sure it to remove them .
Posted on Sep 10, 2009
I need to replace the CMOS battery in my Gateway 7330 laptop and I cannot find out where it is
It is just below the keyboard under the palm rest. Remove all of the screws from the bottom of the unit, carefully - from the left side, pry up the trim panel that has the power button (careful since the power button board is screwed into this panel), then remove the screws for the keyboard, slide it up towards the LCD to release it, remove its ribbon cable, you should be able to gently pry the upper and lower case halves apart enough to see the battery. The cases will NOT seperate!!!!!!!!! I then used a small straight blade screw driver to pop the battery out. It was a CR 1220 3v lithium coin type battery in my 7330GZ. I had to go to a specialty battery store to get one! Hope that this helps!
Nov 05, 2010 | Gateway 7330GZ (890552601318) PC Notebook
Have gateway lt2016u, i need to know how to take it apart
remove battery and all screws on bottom including the three screws in the battery compartment turn over and starting in the top middle of keyboard ( abvove the f8 key ) pop keyboard up remove keyboard cable and lift away keyboard remove all screws from under keyboard and up plug the two cables lift top cover off you now have access to all inter parts
Oct 15, 2010 | Gateway Computers & Internet
REPLACE GATEWAY LAP TOP TOUCH PAD
HI THERE!!
Replacing the touchpad of your laptop is not difficult but because laptop parts are very delicate you need to be careful
To remove the touchpad you need to remove the top cover, also known as the palm rest
1.Power off the Gateway laptop, then disconnect the AC adapter from the power jack. Remove any other devices connected to the laptop.
2.Place your hand on a bare metal surface to release any buildup of static electricity. Close the lid to your laptop and turn the computer over.
3.Slide the battery lock over to the side to pop the battery out from its compartment.
4.Set the battery aside, then turn your computer over once again so that it's facing up. Rotate the laptop so that the back (not the bottom) is facing you.
5.Remove the two screws securing the bezel in place from the back of the laptop
6. Open the lid to the laptop, then insert a flat-head screwdriver underneath one end of the bezel to loosen it from the top cover. The bezel is located just above the keyboard, but below the monitor
7. Carefully remove the bezel the rest of the way. Insert the end of the flat-head screwdriver underneath the top of the keyboard to pull it away from the laptop.
8. Turn the keyboard over and place it face-down on the top cover. Remove the cable connecting the keyboard to the motherboard. You may need to pull back and unlock a connector securing the cable in place.
9. Set the keyboard aside. Remove the four screws located just beneath the display panel, then remove the cable connecting the monitor to the motherboard. Carefully set the LCD display aside.
10. Remove the four screws located near the center of the top cover. Release small blue and white cable connecting the touchpad to the Gateway laptop.
11.Pull the top cover up from the base of the laptop, removing the touchpad along with it.
NOTE; you can remove your touchpad and swap it out with a new one, but you can also buy a top cover with a touchpad pre-installed.
Jul 08, 2010 | Gateway MT3705 Notebook
How can I open the case of gateway solo 2150? I
There is some information on FixYa for this already which can be found at the post below. Generally with a laptop, you'll have some hidden screws under a bezel on the top of the keyboard area. You gently pop this off with a small screwdriver and underneath will be the screws that hold the keyboard in. After removing these, you generally can disassemble the rest of the laptop.
http://www.fixya.com/support/t565004-opening_gateway_solo_2150_laptop
Mar 28, 2010 | Gateway Solo 2150CS Notebook
Removing keyboard aspire 6930z
It was simply a case of prying the keyboard out of its location. There three or four small tabs at the top of the keyboard and a couple down each side. By using two small screwdrivers I was able to prise the keyboard away from the surrounding casing and thereby release the tabs one at a time. Because of the flexibilty of the keyboard, the side tabs were no problem. After unlocking the ribbon from its holding position, by lifting the black catch, I fitted the new ribbon lead. Refitting is a reversal of the previous procedure. However, the new board will need some pressure on it, to locate it back into place. A test prved the success. Shame I couldn't get the information prior to dismantling.
Dec 29, 2009 | Acer Computers & Internet
My batter wont charge.
first you need to check that is the light on the power cord on the adapter is coming if yes then it is supplying the current to teh machine and it is not charging the battery then mother board needs to be replaced if the light on the adapter is not coming up then need to chage the adapter .
Mar 27, 2009 | Gateway MX3560 Notebook
Gateway 4530 keyboard replacement
You don't have to take off the bottom.
You need to take off the panel right in front of the screen
1. Pop off the strip in front of the keyboard.
2. Unscrew the 3 screws.
3. pop off the panel that has the startup button on it.
4. Take the keyboard and put in the replacement.
5. To put it back together.
Oct 22, 2008 | Gateway 4530GZ Notebook
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
CD Drive replacement
thake out the screws on the bottom of the lap top then there are 3 very small clips holding in the keyboardone at the control key one at the space bar and one at the down arrow key push thes back and lift out the keyboard it has a cable conector on it so be carefull then you will see two screws holding in the cd drive and a ribbon conector remove it by pushing forward the small ribbon holder then remove the drive
Oct 29, 2007 | Samsung X05 Notebook
Open Questions:
Motherboard Repalcement I have a laptop - Details of the laptop: Gateway MX3560(model) serial # N625AC1052628 ( on the back of the laptop) Motherboard part number # 103501(required item) The motherboard of this got damaged and is not available.So, i wanna know, can i replace it with any other motheboard type - if there is any other motherboard which is compatible with this type.IF yes, please inform me as i am really worried about it. Other details are as follows - Processor Intel® Centrino? Mobile Technology with Intel® Pentium® M Processor 735 (2 MB L2 Cache | 1.70 GHz | 400 MHz FSB) Chipset Intel® 855GM Screen 14-inch Widescreen Ultrabright WXGA TFT Memory 512 MB DDR (1 × 512 MB) SODIMM (PC2700) Expandable to 1.5 GB Video Intel® Extreme 2 Graphics 32 MB Shared Video Memory Audio AC '97 2.3 Compliant Audio Built-in Stereo Speakers Hard Drive 80 GB HDD (4200 RPM) Optical Drive DVD +/- RW Multi-Format Double Layer Write maximum: 8X DVD +/-R, 4X DVD +/- RW, 2.4X DVD+R DL, 24X CD-R and 10X CD-RW disks Reads maximum: 8X DVD-ROM, 8X DL/+RW, 24X CD-ROM disks Media Reader 4-in-1 Digital Media Manager Secure Digital, Memory Stick, Memory Stick-Pro, and MMC Modem 56K ITU V.90 Fax/Modem Network Intel® PRO/Wireless LAN 802.11g SecureEasySetup? 10/100Mbps built-in Ethernet Pointing Device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces 3 - USB 2.0 Ports 1 - IEEE 1394 port 1 - VGA External Connector 1 - RJ11 1 - RJ45 Microphone In Headphone / Audio Out Battery 6-cell Lithium-ion Dimensions 1.24-inches H × 13-inches W × 9.7-inches D Weight 5.24 pounds
Jan 07, 2009 | Gateway MX3560 Notebook
Gateway MX3560 Notebook Logo
162 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
