Question about Refrigerators
Refrigerator is Warm and Freezer is Cold
Freezer is running 0 degrees and the refrigerator is at 65 degrees. Setting is all the way down to lowest setting. Garage where it is located is 101 dgrees.
Electrolux Refrigerator Model FRT18B4AW2.
  • Huachuca Sep 09, 2009
    I did pull the panel off the back of the inside of the freezer and the coils are iced over. Fan is working. How do I check the heater and the defrost timer? Where are they located and what am I looking for?
  • 725 Answers
The hot air does have an effect on the system, but it should be cooling better than this. Your defrost system may have burned out. Look at the heaters first, then check the defrost timer. They both may need to be replaced. Call us for parts and we'll be sure to get the right ones out to you. Hope this helps! :>)! Ella
Posted on Sep 09, 2009
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Frigidaire side-by-side water & ice in the door Model #GLRS234ZAW1. The refrigerator side freezes with its thermostat any where above the lowest setting. Also the freezer thermostat has to be only a...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 22, 2011 | Refrigerators
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
I have a frigidaire side by side refridgerator / freezer. Currently my freezer is about 34 to 40 degrees. The dividing wall between the ref. and freezer is warm to hot depending on when you check it. ...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 03, 2011 | Frigidaire FRS26H5AS Side by Side...
The freezer is only cooling to 20 degrees. It is maintaining 20. Started two days ago. The compressor is running continuous. If I tuen the thermostat down, the compressor will cut off. But only on the...
heatman101
Dec 27, 2010 | Kenmore Refrigerators
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
