Question about Pool & Spa
Water is leaking out opening holding a thermobulb on ABG100
Water is leaking out of an opening that holds what looks like a thermo bulb on the water inlet manifold. The probe sits in an open (now that is) tube on the top of the manifold. Is there a fitting or gasket that is missing?
  • jdcoffin Sep 10, 2009
    There are no threads to thread a well into. It is a plain (approx. 1/2" copper tube nipple). Looks like there shoould have been some type of compund that sealed the probe in or something like that that. This is on a Hayward, above grond heater, ABG100. i assume a 100,000 heater. Natural gas fired. The probe is on the water inlet manifold just past the 1-1/2" coupling that joins the heater to the pool intale line. Do you have another thought?
    President:
  • 1,378 Answers
It sounds like you need a new well. If you can get the make and model number off the heater we can quote you the part. Contact us thru www.arrowpools.net.
Posted on Sep 10, 2009
  • John Prohaska
    John Prohaska Sep 10, 2009
    Unfortunately, you're only option is to replace the heat exchanger or the heater. That well is part of the heat exchanger itself and can not be replaced. Once it leaks, it is shot. The rest of the metal is also going to be compromised making it not worth fixing anyway. New exchangers are nearly half the price of a whole new heater. If the leak has been going on for some time and damage to other parts from the leak is possible replace the heater. If the leak is recent and not much water has flooded the heater compartment, replace the heat exchanger.
Why after cleaning my thermos with bleach does it no longer holds heat?
The bleach would not have affected the inside of the thermos, but it may have deteriorated the seal of the cap? Try filling it with water, cap it and turn it upside down and leave it for a few hours, see if you get a leak. Or you could submerge it in the sink and look for air bubbles.
Mar 02, 2015 | Stanley Classic Vacuum Thermos 16-Ounce...
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
I just bought a suzuki outboard dt65 it sat for 6 years what do i need to do for water ready
remove carbs and clean jets etc ! clean or replace fuel tank and check primer bulb and line not perished ! check compressions and sparks ! remove gearbox and replace the impellor even if it looks ok and replace the gear oil ! run in tub of water for an hour to check cooling and the thermo opening also check no fuel leaks etc !
Jul 24, 2011 | Suzuki Boating
After my faberware perculator brews it will reperk after a lil while Is this a themostat problem
Thermo is OK
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. I have the parts. send the model # callahanronald@att.net. Good luck
Jan 28, 2010 | Faberware Coffee Makers & Espresso...
Coffee perculator is not geting hot enough
Hi, you have an 8 cup pot made in China.
Oct 30, 2009 | Faberware FCP280 Coffee Maker
Faber-ware automatic percolator model L1360 US no longer heats water well. It is in good condition. Suggests for repair?
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers Good luck. bobbyone
Oct 25, 2009 | Faberware Coffee Makers & Espresso...
Modelp r 134b 4cup faberware comes out like
Oct 11, 2009 | Faberware Coffee Makers & Espresso...
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
How do I put the inners together? where does this spring go
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white rope that runs around the bottom of the pot. You have 1-nut and 1- screw to remove. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers good luck. bobbyone
Mar 28, 2009 | Faberware Coffee Makers & Espresso...
Pool & Spa Logo
81 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
