Hiya - wonder if u couldd help me pls? How do i fix a new belt to my white knight CL767 tumble dryer please?
here's hoping!
Patsy
Hi Patsy, I'm afraid you will need an approved engineer to do this because;
The top, the rear and one of the side panels will have to come off or the front in some cases, the drum will have to be taken out of its housing so the belt can slipped round the drum.
Then the drum will have to be re-lined in to its housing, the panels replaced apart from one side nearest the motor.
Then the belt will have to stretched on to the motor spindle with a special tool and lots of strength and sweat.
I have done many White knights and it does'nt get any easier!
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
SOURCE: White knight tumble dryer making
I have this banging problem, it sounds like a plastic ball rolling about inside it
SOURCE: WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
How to Replace A
White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance
Video Repair help see our video section
White knight tumble dryer not heating this video show you
how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux,
Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into
our search bar at http://www.apart4u.co.uk/ TEL 08455218000
SOURCE: white knight tumble dryer CL432WV wiring diagram
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
How to Replace A
hiya
yes i do
thanks
yes
Do you own tools to do the job and are you somewhat mechanically inclined?
Do you have a new dryer belt?
