Question about Mitsubishi Heating & Cooling
Service for Mitsubishi air conditioner in London, Ontario, Canada Fluttering noise in interior unit (M5Y A24NA)
Problem solved
Posted on Sep 10, 2009
How do i dismantle the aicon unit
First thing u have do is pumpdown the unit close discharge line wait for few seconds check the suction line when coolness of suction line goes also close the suction valve and then dissconect all power supply then u can remove copper tube and easily dismantle a/c unit.
Oct 05, 2014 | Mitsubishi MSZ-A24NA Split System Air...
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
Installed new unit inside and now outside unit will not operate, have checked wiring several times.
Make sure there is power, make sure wiring is correct and gas valves are opened after performing vac on system run on test cool and check for fault codes on controller
Jul 03, 2011 | Mitsubishi MSY-A24NA Air Conditioner
Does not blow cold or hot air
Haved you cleaned the filter?? Clean them! It might be out of refrigerant. Have the unit professionally checked.
I take the time to help, so please rate me!
May 30, 2010 | Mitsubishi MSZ-A24NA Split System Air...
MSZ-A24NA Split System Air Conditioner: it stopped heating, air comes out but no heat, brr...
Is it defrosting??? Your problem is quite brief and that is the only advice that I can offer based on your question.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | Mitsubishi MSZ-A24NA Split System Air...
How do your read the serial# of a MUY-A24NA unit ,
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Mar 26, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
103 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
