Hii have a 60 in phillips hd tv model 60PP9363H/17. today the colors are off green and red and in certain spots on the screen the pictured is doubled. I tried to realign the colors but in the top left corner the cross hairs will not line up and it appears that some cross hairs are slanted to the four corners of the screen what do i do?
    Sergeant:
    Champion:
  • 273 Answers
Comvergencia and also review the rings of the cannon comvergencia try demagnetize the screen
Posted on Sep 09, 2009
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
In need of better picture
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 23, 2009 | Philips 60PP9363 60" Rear Projection...
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Picture is warping and colors are seperating giving a picture that looks like a 3D picture without the glasses
you need to replace both convergence Ics. Post the model number of your set and I will post the correct IC numbers as well as alink where you can get replacements with free instalation instructions. Respond to this same post so I will have access to your symptoms when you post the nodel number.
Jun 30, 2008 | Philips 46PP9302 46" Rear Projection...
My phillips model 60pp920217f has a horrible picture...no green to the color
The green CRT coolant has congealed thats whats giving you the green halos. Change the coolant in the green and blue and your set will be fine. red is never affected so the red coolant should be fine.
May 07, 2008 | Philips 43PP9202 43" Rear Projection...
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Philips 60PP9363H/17
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 11, 2008 | Philips 60PP9363 60" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
