Question about Sharp BDHP20U Blu-Ray Player
No Pix I have a Sharp BD HP21 Player conneted to TV via HDMI But only getting "UNSUPPORTED SIGNAL" PLS CHECK DEVISE OUTPUT msg How do I get a Pix to possible change any settings
  • aaron600 Sep 10, 2009
    Thx for the link
    I think I may have found answer but no one has responded as to were I can Purchase the
    Atlona AT- HD 560 for upscaling 50Hz Pal to 60Hz NTSC and for approx how much
    Thx again
  • Sharp Master
  • 19,396 Answers
Do the following troubleshooting steps:
  • Unplug player and TV from power, wait ten minutes, and connect everyting back.
  • Try a different HDMI port on TV.
  • Go to display settings on the Sharp, and set to High definition/HDMI.
  • Go to display settings on the Sharp, and ensure that signal is set to right PAL / NTSC settings.
  • Try using a different HDMI cable.
If still no luck, then test player using a different connection and possibly test on different TV.
HDMI cables must be connected and disconnected with the devices off, or you can blow HDMI port.
Posted on Sep 10, 2009
  • 164 Answers
Http://www.tomshardware.com/forum/25316-4-hdmi-ntsc-flavours
this link will take you to a website that can explain things better than I could. Its a little bit more complicaded than just having HDMI. click on the link and maybe this will help you.
Posted on Sep 09, 2009
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
I can't get a signal between my Sony Blu-Ray Disc/DVD Player and Samsung HDTV monitor. They are connected via a HDMI cable. A brief message on the HDTV reads "Not supported".
First, try to reset resolution of HDMI Sony BD output.
Unplug HDMI cable from TV and change to Component connection to reset BD output resolution.
Than after you entered to resolution menu, choose to standart resolution 720 or 480 i.
If above methode working, try to reconect HDMI cable again to HD TV.
If any problem with picture or still "Not Supported" messege appear, i suggest to change HDMI cable first.
i hope its work.
Mar 14, 2011 | Televison & Video
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I have a sharp aquos bd-16u blue ray player, I get the audio signals but I'm not getting any video signal with the component output. My tv does not have hdmi inputs but it does have component inputs. What...
1. could be the cable you using.
2. Could be you in the wroung input
3. RaRE but it could be the Blue ray itself
You might want to try new cables the R,G,B ones..
Yiou can try it on another tv to see if that works.
in rare instances you could have a dead on arrival there,
Thanks I hope this helps please do be considerate and leave postive feedback and ratings.
May 30, 2010 | Sharp AQUOS Blu-ray Disc Player
I have conneted the HDmi to the player and then
hi have you set your onkyo receiver if you have connected your hdmi lead to the receiver and an hdmi from receiver to tv you need to assign these connections via the menu on the receiver first then you will get a connection
Feb 24, 2010 | Onkyo TX-SR606 Receiver
I just purchased a denon avr-1610 receiver and I cannot get picture back to my tv through the hdmi. I have a starchoice dvr which is dvi to hdmi, I come out of my satelite into sat/cab then out of my denon...
One possible reason is the HDCP (copy-prevention)-encoded signal from the DVR, which will transmits through to one device (the receiver) but not to a second (the TV). As an experiment and a possible solution, try reconnecting the HDMI cable from the DVR directly to the TV (provided you have an extra HDMI input on it), and using the component-video or S-video plus either digital or analog audio outputs to connect your DVR to the receiver. If this works, I think that the HDCP is the problem and this is the only solution.
It may be a little inconvenient to remember to switch inputs on the TV as well as the receiver, but you could probably program your remote with a macro to do both. The component video (or, more likely, the S-video) is also the best possible video signal you can use for dubbing to any DVD recorders, if you have one connected to the same receiver. You can still keep the HDMI connected from your PS3 (or other BD/DVD) player to the receiver, and from there to the TV, since that does seem to work -- if you don't mind turning on the receiver every time you want to watch a BD or DVD. My recommendation, however, is to connect all your video signals directly to the TV via HDMI or component, and use the receiver only for audio, or for switching of lower-level video signals like S-video that you can use for dubbing. That way you can always check the DVR or BD or DVD quickly without powering up your receiver, which takes a few seconds and much more power.
Feb 13, 2010 | Audio Players & Recorders
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
No picture from Blu-ray
If the TV works fine with other sources the problem is the HDMI output is not enabled on the BD player.
Most BD players do not output both HDMI and composite formats simultaneously. Check to make sure the HDMI output is selected on the BD player and the TV. This information is in the manuals, read the book.
Cheers
Jan 15, 2010 | Hitachi 57F59 57" HDTV
I tried to burn a short movie on a normal DVD as a BD-disc
may be the formatt u write s not supported by ur sharp bd hp21
Sep 25, 2009 | Televison & Video
Sharp BDHP20U Blu-Ray Player Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
