65 inch rca scenium will not turn on, what steps should i take or try to get it to turn on. Please help i know nothing about tvs
  • aje4933 Sep 09, 2009
    The model number is hd65w20 and also the blue light is on but thats it .
  • 476 Answers
Without a model the only thing i can suggest is to unplug the tv from the ac outlet, wait for a few secs and replug, try power then. check the power light indicator they usually blink at least to indicate if there is a lamp failure or an overheat condition, you'll probably find this in your owners manual if you don't have one you can download from the rca website, rca.com, you will need your model number.
Posted on Sep 09, 2009
Testimonial: "fast response. great tips, thanks a bunch."
  • 11,896 Answers
Your power supply is most likely faulty. Very common especially in newer tv's. I would call around and get quotes from a few different people first. Unless you want to order a service manual and try to test for the faulty capacitor or resistor in the power supply and replace it yourself.
Testimonial: "Very fast reponse and helpful hints, thanks"
How do i fix my rca lcd tv that keeps flickering
Flickering can be adjusted after enter its service mode option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 17, 2016 | RCA L46WD250 46-Inch LCD Scenium Flat HDTV
RCA SCENIUM trys to start up but wont start
most of the time in situations like this fusses are blown check them all and if still problem let me know remember you have more than one fuse in tvs
Nov 18, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My 40 inch rca scenium will turn off for a few seconds and then turn back on all by itself. When it first started it would only happen once and a while now it will happen up 4 times in an hour. Any help...
First try cleaning front Panel contact switches if cleaning them does not work then replace all 7 of them. Call Mats 1-800-628-1118 contacts are your Off/on ch- ch+ vol- vol+ menu button
Nov 22, 2009 | RCA Scenium D40W20 40" Rear Projection...
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
MY RCA R61WH76 61 INCH TV IS BLURY AND LOOKS LIKE IT HAS 3 PICTUR
RCA Scenium Profiles HD61 TV IT'S AT 480i how I get at 1080i or 720i please help....thanks...
Jul 02, 2009 | RCA R61WH76 61" HDTV
Rca 42 inch hdtv the screen is fuzzy and turning blue .. how can I fix this problem
please check the arial connection also please check the colour it needs reajusting. take it back to b/w and retune.
May 04, 2009 | RCA Scenium D40W20 40" Rear Projection...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
Fuse locations for RCA Scenium HD65W20
there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
I have an rca scenium
turn off autoformat in customer setup
Feb 25, 2007 | RCA Scenium HD65W20 65" Rear Projection...
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
