Question about Insignia Televison & Video
The tv screen is zoomed in. how do i get it back to normal?
    President:
  • 1,077 Answers
On most remotes, there should be a button that says SCREEN MODE, VIEW MODE, PIC MODE, or DISPLAY MODE. Keep pressing that button on the remote to change to different modes. If you have trouble finding the right button, tell me your TV model number so I can look up the picture of the factory remote.
Posted on Sep 09, 2009
Can,t get a normal picture on screen all I get is a zoom picture
You will need to get into the tv's menu and change the "settings" area under display properties to read "normal" instead of "Zoom". Change that and you will be back to being able to see the entire display.
Good Luck
Rich Lilja
Sep 20, 2013 | Sony KDL46EX400 46 in. HD-Ready TV
Tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Apr 07, 2012 | LG Televison & Video
LG 50" the pitcher is off the screen each side by
Ok, first make sure you or someone in family didn't hit the "HD Zoom" on your cable remote or whatever kind of remote you have. On ours - Cable- if you hit it once it is in "Normal" picture which on ours has black around edges on a non Hd channel. Then if you hit it again it Zooms once makes pix very large and if you hit button a third time brings it into a wide screen Zoom that fills the Tv screen. If we are viewing HD channels I put it on Normal which will fill the screen and give you the best HD pix. If we are viewing a NON HD channel, then normal will have black on sides, so I hit the Zoom a couple times to fill in the screen. My brother in law had this problem and couldn't figure out why his Sports channel Scores were always half cut off the screen! it was zoomed in too much for that channel. His sports channel was in HD so needed to be on normal instead of zoomed in.
if it is not the Cable remote then this is a second possible cause:
The other thing that happened to me was - we hardly ever use our original TV remote that came with the TV. but one day our picture looked weird and the cable remote didn't adjust it. One of us had hit the "P SIZE" button on the TV remote. this changes your pix from - 4:3 ratio to 16:9 ratio and vice versa. I put clicked that button and on the TV it shows whether it is at 4:3 or 16:9. For newer wide screen TVs you want that set at 16:9 ratio.
All cable company remotes probably are a bit different so check with your company ... to find out where the zoom control is on their remote.
Feb 27, 2011 | LG Televison & Video
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Dec 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My proscan tv went into wide screen....everything shows up bigger. how do I get it back to normal? By wide screen, I mean if there are 2 people sitting at a table talking on screen at opposite sides of...
It sounds like you accidentally enabled a zoom feature or something similar.
Most remote controls should have a clearly labeled "zoom" button or a "picture size" option. If not, go into your TV's menu and look for something zoom related.
If this doesn't work, just go ahead and toy around in your TV's menu. I strongly suggest writing down the default settings so you can go back to them if you screw something up.
Aug 27, 2009 | Proscan Televison & Video
Akai stuck on zoom??
Run it through the different 'MODE' settings. it may really be on zoom, or just confused.
Also, try unplugging it for a minute. plug it back in and see if it's better.
Aug 15, 2008 | Televison & Video
Zoom in and zoom out
Hi.
Try looking in the menu under PICTURE. see if there is picture size adjustment for picture size eg 16 x 9 4 x 3 normal wide.
Nov 10, 2007 | Bush 2871NTX 28" TV
Sansui 54cm TV zoom
push the pip buttton
Nov 08, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
131 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
