Question about HP DeskJet 5550 InkJet Printer
HP Deskjet 5550 green and amber lights flashing printer won't print catridges stuck on left of printer can't get to one of them re-booted PC and checked for paper jam - no luck checked cables - seem OK
    President:
  • HP Master
  • 2,022 Answers
Remove the catridge and see also the steel rod is not dry apply some lubricant oil on the head rod.
Posted on Sep 10, 2009
Not printing
Check that there still isn't a piece of paper jammed in the mechanism. Also check that the paper out sensor isn't stuck. Delete the item from the print queue and reboot both the printer and computer.
Oct 05, 2009 | HP DeskJet 5550 InkJet Printer
Whilst printing on lightweight card, the exit for paper was blocked with a folder. Prunter made nasty grating noise and stopped! No paper blockage. Green power light and amber light above now flashing and...
Have a read of the following
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00681585&lc=en&dlc=en&cc=uk&lang=en&rule=7865&product=71896
Hopefully this will resolve your problem
Aug 04, 2009 | HP DeskJet 5550 InkJet Printer
Printer has been idle for several weeks.When I came to use it the printing is broken and faded looking.How do I clean the cartridges?
HP Deskjet 5550 Printer.
The deskjet printers should not be kept idle.
At least once in two or three days, you can take one page print out.
This has to be done, otherwise, the inks both Black and colour will get frozened and sometimes it will become dry at the catridge mouth.
Black Ink is 56 and Colour is 57.
Solution :
01. Manually remove both catridges from the printer carefully.
02. Shake the catridges with full force pointing towards ground. You can find out now, that ink is coming out from the catridges which was frozen or dried up.
03. Clean the cartridge drive with a nice cloth and cleaning liquid.
04. Re install both catridges and take a test print out.
05. Recommended to have a service contract with local HP Authroized printer vendor to have a regular maintenance at least once in a month.
Jul 21, 2009 | HP DeskJet 5550 InkJet Printer
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. 4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Jun 09, 2009 | HP DeskJet 5550 InkJet Printer
Lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
May 08, 2009 | HP DeskJet 5550 InkJet Printer
Hp deskjet 5552 printer Problem: cartridge carriers STUCK on left hand side of printer . Yellow and green lights on together and flashes. Checked all connections. Mill
Here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Mar 18, 2009 | HP DeskJet 5550 InkJet Printer
Printer won't print
Did you peel the piece of paper on the ink cartridge?Or if that doesnt help do this get the cartridge out and then dip some water on the ink leaking part with a piece of paper and well see what will happen.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
The cartridges are "stuck" in place - won't move left or right - yellow lights is flashing
With the power off. Push the carriage to the left about 4". Power up the printer. It should go through its normal reset. When it's done making noise look in & see if it went back to the center?
Open Printer & Faxes. Your default printer should have a check nex to it. make sure it is the 5550. Click the 5550 once so it's highlighted. Click file & open. Clear anything that is waiting to be printed. Close all the opened windows. Re-start the Pc.
I should list HP's suggestions too:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00034342&lc=en&cc=us&dlc=en&product=71896&rule=45014&lang=en
Try a test page even is so. Post back...
Feb 07, 2008 | HP DeskJet 5550 InkJet Printer
Hp 5550 blinking
remove the 2 ink catridge and cover it back you will see only catridge error light peeping. off it and on it back then put the 2 catridge back i hope this will solve your problem. from .
Aug 10, 2007 | HP DeskJet 5550 InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
315 people viewed this question
Ben Johnson
