F- MESSAGE WHIRLPOOL FRONT LOADER
HELLO,
I HAVE A WHIRLPOOL SPORT FRONT LOADER STANDARD MODEL # H61B3A0A(3B).
THE WASHER HAS A MESSAGE APPEARING F-
ALL THE LIGHTS ARE BLINKING ON THE WASHER
jsrock516
  • 5911 Answers
SOURCE: i have a whirlpool duet
"F21" is a Drain Problem error. If you press PAUSE/CANCEL and it does not correct the problem, you will have to perform the following:
- First of all, the manufacturer recommends unplugging the washer for at 30 minutes before assuming you have a component failure. In some cases, this is all that is required to clear common "glitches". If the problem can't be a explained away as a momentary computer related problem, then continue below:
- Inspect the Drain Pump for clogs - the following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
- Inspect the drain hoses for clogs - this includes the drain line that runs from the bottom of the wash tub to the inlet side of the pump, as well as, the drain hose that exits the puimp and runs to the standpipe at the wall.
- Inspect the drain hoses for kinks.
If the error code still persists after you perform all these preliminary measures, it is recommended that you replace the drain pump. It does not take much to damage the drain pump in this washer. If foreign objects remain in the pump for extended periods of time, it can potentially damage the impeller and motor. The result will be a drain pump that APPEARS to be running, but isn't pumping water like it should. If the pump is damaged, please let me know and I can assist you with locating replacement parts. The cost is usually about $100 or less, if you perform the repairs yourself. I also have step-by-step instructions if needed. I will need to know your MODEL number if this is the case. Hopefully, it won't come to that. The answer is not spend MORE money on another appliance. You can learn through expert advice how to repair your appliances yourself and avoid the expensive service call. I hope you agree.
I hope you find this information helpful. If you require further assistance, please let me know.
Posted on Sep 11, 2008
SOURCE: Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
SOURCE: whirlpool front loader 6lhw0050pq washer won't
replaced belt
Posted on Jan 09, 2010
  • 149 Answers
SOURCE: F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Posted on Mar 27, 2010
  • 662 Answers
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
Posted on May 17, 2010
Hello I have a Kenmore elite h5 front loader . Error code f99 . How do I reset the washer ?
https://appliantology.org/blogs/entry/649-troubleshooting-technique-for-checking-the-mcu-in-a-whirlpool-duet-sport-washer/
Dec 09, 2017 | Kenmore Washing Machines
Washer is leaking, looks like it's the front bottom of washer. How do I take the washer apart to see where the problem is?
what is the make and model of your machine on a whirlpool type unit it would be like in this video http://www.youtube.com/watch?v=DwV71h86Gxw not sure if you have top loader or front loader until i see the model number so message me back with the number Thanks again Rick
Jan 09, 2011 | Washing Machines
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Keeps flashing F-O1, WILL NOT WASH, WHY?
You have a bad controller take the top off and on the right side you will see a white box that is the part that need to be replaced.
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
