Question about Epson Stylus Photo R220 InkJet Printer
What is the sequence to reset the printer - Epson Stylus Photo R220 InkJet Printer
6C10 Error - Absorber counter reset sequence does not work. Is there another way to reset this counter?
Canon has changed all of the new printers and eliminated the built in reset ability of the printer. You must have specific software to access the Service Mode and from there you can reset the waste ink counter. Contact me at bud4golf@att.net for detail
Jan 05, 2015 | Canon PIXMA MX860 All-In-One InkJet...
How to replace dell 1250c fuser?
To reset the life counter:
  1. Enter the printer's Tech Mode by quickly pressing the sequence of keys Menu > Up Arrow > Left Arrow > Tick > Right Arrow > Cancel > Menu. If Tech Mode doesn't appear, press the key sequence again as quickly as possible. A delay in pressing the keys will stop the menu from opening.
  2. Select Tech Menu > Data Setup > Clear Fuser Count.
  3. Restart the printer.
Read More... Replace the fuser and reset the life counter on Dell 5330dn laser...
And Dell Printer Support
Thanks,
Jul 30, 2014 | Dell Office Equipment & Supplies
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
I have an hp c4380 photosmart printer. It prints very slow. Please help.
Try different modes - fast, draft, set correct type of paper
Nov 20, 2010 | HP Photosmart 3210 Printer
Printer never completes the startup sequence, it
just reset the printer
unplug the power cable without turning off the printer
press and hold # & 9 Button
while holding down pluggin the Power cable and it will reset the printer (everything)
**** U will lose everything that has been saved in the printer settings
Oct 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
Espon 320 stuck with service required error message.
There is no button pressing sequence for this printer Epson got wise to that one.However check this out for a resolution.
http://www.wasteink.co.uk/epson-ipr-reset/
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Ciss ink won't work on hp c7280
Must use included HP "starter ink" cartridges before the CISS can work. There's a 3-button sequence [OK-Cancel-Black Button] sequence when powering on that will reset the printer and bypass the "starter ink" wall you're hitting
Jun 11, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Feb 21, 2008 | Brother HL 1240 Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Epson Stylus Photo R220 InkJet Printer Logo
116 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
