Question about Husqvarna Chain Saw 20" Bar
Need to know how to change oil pump on 18'' 350
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
You need to get the clutch off first. In order to do this it is best to invest in a clutch removal tool. You can damage your clutch and fan fairly easily if you do not use one. After you get the clutch off you have access to the pump. The pump is very easily removed by removing the one screw that holds it in place. You will have to wiggle the forward side out of the boot that is attached to the inlet hose. There is a tiny impellar that spins when the clutch is engaged. Sometimes this has been stripped and is the case of no oil. You more than likely just have blockage that needs clearing. Check that before you you order any parts.
Posted on Sep 09, 2009
How to change a oil pump on a 2004 Suzuki forenza car with a 2.0 engine
I think the oil pump is in the oil pan. Messy difficult job. Not for most people because you really need a lift. How do you know you need a new oil pump?
May 04, 2015 | Suzuki Cars & Trucks
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Jul 16, 2011 | Coleman Garden
I hav 2001 ford taurus 3.0 single head cam engine makes noise , mechanic said that oil pressure is low n need change oil pump. but oil light not comes on always, it becames on only driving, when I...
That sounds like a pump... the oil pump is inside of the engine. You need to drop the oil pan to gain access - however, you will need to pull the motor to do that.
Jan 25, 2011 | 2001 Ford Taurus
Oil pump removal oil pressure
I need to know what year model Sportster you're working on. I know the book says you can change the oil pump without removal of the engine from the frame but it ain't that easy. Let me know exactly what year model you're working on. You may NOT have to pull the pump.
Are you certain you have no oil pressure? Pull the spark plugs and remove the oil filter. Spin the engine with the starter and see if oil pumps out of the oil pump adaptor. If it does, you have oil pressure and the oil pressure switch is lying to you. If your bike is equipped with an Evolution engine, 1986 or later, it will have hydraulic tappets. If you indeed do not have any oil pressure, the tappest will rattle badly.
Good Luck
Steve
Oct 24, 2010 | 1979 Harley Davidson XLH 1000 Sportster
I have to change the oil pump of my 2004 titan
BEHIND THE TIMING COVER ON THE CRANKSHAFT
Mar 14, 2010 | 2004 Nissan Titan
Oil light
To reset the oil change maintenance light is somewhat tricky.
When you first turn the car on ( without starting it ), you have 5 seconds to pump the gas 3 times. If it's done correctly, the display will say RESET in a few seconds.
Jun 03, 2009 | 2006 Chevrolet Trailblazer
EMGLO AM78HC4V pump oil
use sae 30 non detergent oil in this compressor let me know if you got any other qeustions
Jan 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Husqvarna Chain Saw 20" Bar Logo
100 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
