Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Fax from computer
Mac- Epson E600 all in one. Can not figure out how to set this up so that I can fax docs directly from my computer. (Ex: Print/print to fax/type in or select fax #.) Any help?
My Epson Label printer is showing as not connected when its connected, when trying to set up or add as new printer.
What shows mac and ip address ? printer or pc ?
If the printer displays them, it means the printer in connected to router electrically.
Check subnet mask and gateway address.
Could be set wrong if the router is not on DHCP.
I guess the issue is in the ethernet components / settings.
Start isolation by elimination of the following
1. Computer -
2. Wifi connection to the router (or)
3. Patch cable connecting computer to the wall -
4. Router -
5. Patch cable connecting the printer to the wall -
6. Printer -
The LAN printer cannot connect to Computer (PC/Mac) directly unless you use a Cross over cable.
Sep 11, 2016 | Epson Tm C3400 Securcolor - Label Printer...
Set up wifi printing. Why am I unable to print documents?
you have to uninstall all other printer software except the epson printer software.after uninstalling all other printer software you have to restart computer
Sep 03, 2015 | Epson Expression Home XP-205 -...
Epson troubleshooting
for iPad & iPhone you can use Epsons App "iPrint"
Wireless Printing with Epson iPrint
    Epson iPrint offers the convenience of wireless printing direct from your iOS™ or Android™ devices. With iPrint, you can easily print web pages, Microsoft® Office™ documents, photos and PDFs over your home or office network. You can also scan and save onto your mobile devices, send as an email or upload to a cloud service such as Box.net, Dropbox, Evernote® or Google® Docs™. Epson iPrint is free to download from Apple App Store and Google Play Store.
for the Mac download the latest software below:
Epson WorkForce WF 2530 All in One Printer
epson-troubleshooting-wutfveiel3ypko01ydor435x-1-0.jpg epson-troubleshooting-wutfveiel3ypko01ydor435x-1-2.jpg
Sep 06, 2014 | Epson WorkForce WF-2530
Says receiving fax but doesn't print
Fax machines can be set to store documents, print docs or do both. If you set it to only print received faxes, it will try to print and give you some kind of error it if fails (e.g. no paper). Did you get an error? if not it either is set to store and not print, or it didnt store it and you have lost it. From the menus on the Epson, look for where items may be stored e.g. 'store' or 'mailbox' and check if there is any doc in there.
Dec 19, 2013 | Epson Workforce Pro Wp-4525 Dnf
When I start the printer it begins printing a site, that I did,nt ask for, and it keeps printng the same site until there is no more paper
1.) turn off the printer., disconnect the connection between printer and computer ( usb cable )
2.) for win ( xp, vista ) cancel pending doc's in the print and fax
3.) reconnect the cable back to your computer power on the printer and try t print.
4.) for mac systems cancel stopped jobs., delete and re add printer in the printer list and then do step ( 3 )
Apr 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Can not get my cx6400 to print from my mac
You need a MAC driver disk or download.
If you don't have a disk, you can download the driver from the Epson site. I've added the direct links to the relevant downloads below, providing your Mac is connected to the internet.
These drivers are only for the Epson CX6400 on Macintosh operating systems.
If you are using version Mac OS 7.6 to 9.2, here's a direct link to the driver download: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7Nsto14LFsNUjuRSXBZZOHy&tc=6
If you are using Mac OS X - Intel, here's the direct link: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7M6qoJ6uYEojoMzz9oApk7e5aobGaUtdawU003D&tc=6
If you are using Mac OS X - PowerPC, here's the direct link: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7Prg898nyvz3fMP+q1RgJB+&tc=6
Once you've downloaded the driver, it may be a ZIP file so unpack it where you can find it and double click the setup.exe file or program icon that unpacked.
This will install the drivers to your Mac computer.
You'll be asked to make sure the printer is plugged in and connected to the computer at some stage so that it can communicate with it and complete the installation.
Good luck
Nigel
The INK Store
http://www.the-inkstore.co.uk
Dec 11, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
