Question about Refrigerators
Will not keep cool any more freezer or fefrigerator
  • 4,070 Answers
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Posted on Sep 09, 2009
Not cooling, freezer is working fine running but not keeping food cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Amana ABB1927DEW / ABB1927DEB / ABB1927DEQ...
Fefrigerator side not cooling properly, around 47 degrees.!! What's up?
heatman101
Jul 27, 2011 | Microwave Ovens
Fefrigerator part not cooling model number dfbb363l serial no# 021706h0000002144
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Viking DFBB363 Bottom Freezer Refrigerator
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
heatman101
Jul 05, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
Refrigerator not keeping cool enough. Freezer staying cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 26, 2011 | Maytag MTB2656G Top Freezer Refrigerator
After a while the power will go to the freezer to try to keep it cool but it will stop keeping the fridge cool
heatman101
Feb 23, 2011 | LG LFC23760ST Side by Side Bottom Freezer...
My freezer keeps gettig ice i the top. It is frost free. It keeps dripping into the bottom and I have to keep wiping it out?
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 04, 2011 | Whirlpool Refrigerators
My kenmore fefrigerator not cold anymore, what should I check first pls!
Hi and welcome to FixYa. I am Kelly.
First check the freezer compartment for signs of ice build up. If the unit is running and not cooling. If you note ice build up do the following.
1. Unplug the unit.
2. Remove the contents of the freezer compartment.
3. Place a fan blowing into the freezer compartment of about 2 hours. (Makes a water mess. Mop and rags required)
4. After 4 hours wipe the internal cabinet dry.
5. Plug in the unit and let run about 30 minutes.
6. Reload freeezer contents.
This is a manual defrosting procedure. It will only provide relief from the symptoms of no cooling for around 2 days. If the manual defrosting returns the unit back to normal temps then you will need to have the unit serviced and the automatic defrost circuit repaired.
The problem can be
1. Defrost control,
2. Defrost heater element,
3. Wiring, or
4. The defrost thermostat.
Any one of the 4 can cause the problem.
If the compressor is NOT running at all the problem can be
1. Defrost thermostat.
2. Defrost control
3. PTC start relay or the KliXon thermal overload (2 part Assy)
4. Run capaicitor
5. Compressor
6. Temp control.
You did not provide a model number in your post so all of the above are GENERIC terms. If you need specific information you will need to respond with your model number.
Thanks for choosing FixYa.
Kelly
Sep 11, 2010 | Kenmore Refrigerators
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
