Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do I get to the power connector on a Electrolux contour 2000
Replacing a throttle sensor for a 2000 ford contour
Hi Donald IM AL the owner of Big As Auto Repair.
Donald this is very easy to do, just unplug the connector, take the to screws out holding the sensor, pull it out and replace the new one. That's it, no adjustments necessary, your done! Hope this helps and please visit my auto-repair-website at: http://www.bigasautorepair.com/
Feb 03, 2017 | 2000 Ford Contour
How do you change camshaft position sensor in 2000 ford contour
If you have a 2.0 liter 4-cyl, it's on the passenger side of the head on the firewall side. On the 2.5 liter V6, it's just below the front cylinder bank valve cove, on the passenger side, on the right side of the engine.
To remove the sensor:
  1. Disconnect the negative battery cable.
  2. On 2.0L engines, remove the air intake resonator.
  3. Unplug the connector from the CMP sensor.
  4. Remove the retaining bolt and remove the CMP sensor.
To install:
  1. Ensure the CMP sensor's mounting surface is clean, and the sensor's O-ring is in place.
  2. Install the CMP sensor and tighten the retaining bolt to 13-17 ft. lbs. on the 2.0L engine, and 71-106 inch lbs. on the 2.5L engine.
  3. Plug the CMP connector in.
  4. On 2.0L engines, install the air intake resonator.
  5. Connect the negative battery cable.
Feb 28, 2013 | 2000 Ford Contour
I have 2000 ford contour with cng where are the
I also have a 2000 CNG Contour, and my fuses are bolted to the driver side strut tower under the hood. It is between the strut tower and the power brake booster. The fuses are covered with a black rubber boot, and the rubber boot is secured with a small zip tie. Just cut the zip tie, remove cover and you will find a few fuses.
SGT Jensen
Oct 07, 2009 | 2000 Ford Contour
2000 ford contour 4 cyl.
If the car had no real power loss problems before have the ting belt replaced ,than it is most definitely out of time.
Apr 21, 2009 | 2000 Ford Contour
Where is the alternator fuse on a 2000 ford contour. can you show me a picture?
fuse #2 7.5 Amp, power distribution box in engine compartment.
Mar 23, 2009 | 2000 Ford Contour
2000 Ford contour se Alternator replacement question
please rate as fixya if this is what you want.
you did not say if 4 cylinder or 6 cylinder. they are different.
here's 4.
SECTION 414-02: Generator and Regulator 2000 Contour/Mystique Workshop Manual
REMOVAL AND INSTALLATION Generator —Vehicles with 2.0L Engine Removal
  1. Release the fuel pressure. For additional information, refer to Section 310-00A . For additional information, refer to Section 310-00B .
  1. Disconnect the battery ground cable.
  1. Remove the intake air resonator.
    1. Disconnect the air cleaner outlet tube.
    1. Remove the bolts and nuts.
    1. Remove the resonator.
  1. Disconnect the fuel line.
  1. Disconnect the ground cable.
  1. Disconnect the generator electrical connectors.
  1. Remove the accessory drive belt. For additional information, refer to Section 303-05 .
  1. Lower the vehicle.
  1. NOTE: The lower bolt cannot be fully removed until the generator is repositioned.
    Fully loosen the lower bolt and remove the upper bolt.
  1. syp~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: There is a very limited amount of space in which to remove the generator. Do not overstress or damage any hoses or cables.
    Lift the generator clear of the engine.
Installation
  1. NOTE: To aid installation, push the sliding bushings flush with the generator casing.
Mar 22, 2009 | 2000 Ford Contour
Power nuzzle keeps stopping
Get a new "Short Cord". These have a habit of going bad at the connector. Only a couple of bucks.
Dec 11, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
