Question about Nintendo Super NES Console
Snes power snes worked last time i used it (few years ago) i think that the power port is missing a part, which i can't find, nor can i find a picture of the back. there are two prongs in the ac adapter port but when i switch it on, it doesn't work. is there a part i can get, can i rig it, or do i just need to get a new one
    Problem Solver:
  • 12 Answers
You may just be better off getting a new one.
Posted on Dec 10, 2007
    President:
  • 894 Answers
Well this is a complicated fix to do on your super nintendo So my best bet would be to buy a new one from JJ games and not worry about the old one or you could have it fixed then.
Posted on Aug 29, 2011
Strange missing pixels/ discoloration for SNES
Hi the prob is the snes system itself its getting worn out
Apr 08, 2012 | Nintendo Super NES Console
Super NES Console: My super Nintendo gets power (red light turns on) ...
Maybe the one that is not turning on to play game is broken then. Ensure that you have a known-good game cartridge inserted before powering on the SNES console. Most older, cartridge-based game consoles don't boot without a game installed.
Does the power light to the left of the controller ports turn on when you turn on the power switch?
If not, check your power adapter and outlet for functionality and good connection.
Check that the reset switch is not stuck. Wiggle it back and forth through its range of motion a few times. If something sticky gets in there it can get jammed in the reset position, which will prevent any game from booting.
You mentioned that there is no image. Are you getting any sound from your games after waiting a few minutes with everything connected and turned on?
If you hear game sounds or music from the SNES, but see no picture and you've already (really and truly) ruled out the cabling and TV, then you might have a bad main board in the console.
If you don't get any video or sound, then it's not booting your game. You can find other recommendations about how to clean game and console connections, but usually inserting and ejecting a game 10-20 times will knock loose or grind off enough gunk to get a game to boot. Try this, and be sure to use the eject lever instead of ripping the game out to avoid console connector damage. If it's still not working, repeat with another game.
May 18, 2010 | Nintendo Super NES Console
My SNES wont turn on. PLEASE HELP!!!!!!!!!
go buy a new one that system is to old
May 03, 2009 | Nintendo Super NES Console
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
SNES works but no color.
Sounds like your AV Multi-out port circuitry is shot. Yest it with an RF adapter, and if it works perfect with an RF adapter, that is the source of your troubles. I'm afraid that the cheapest solution is to buy a SNES motherboard (about $20.00), which is a lot cheaper than a repair shop soldering in new components to fix it. It's not something you can do on your own.. Google SNES Motherboards type 1 or 2
Apr 08, 2009 | Nintendo Super NES Console
I'm missing a cable for my SNES but I don't know which one
its an rf cable you can buy third party ones if you search on the internet. also if you happen to have a video cable for gamecube or n64 you can plug that into the slot on the back of the snes and it will work. Im not sure what that slot is called but its the only one that cable will fit into.
Feb 22, 2009 | Nintendo Super NES Console
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Starview 4 not working
reset to factory default then do a rescan that will fix it
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Nintendo Super NES Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
