Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Control top indicator light stays on even when stove is off
  • 999 Answers
A sensor on one of the burners is bad.
Eric
Posted on Sep 17, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Red light on stove stays on even when the burner is off
One of the switches has a short causing the light to stay on. Replacing the switch is the only way to correct the condition.
Sep 10, 2013 | Stoves Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My hot light stays on and every thing is cool to touch
yes , hopefully you have a seperate indicator light for each of the elemnts, makes it easier to see which has gone bad, but if yo know which burner you were usins at time of incident then you can assume that it was that elemnet. replacement of the elemnt is required, for a it has a short in the theremistor, not a hazard, more of an inconvience, so i would have it taken careof but no need to rush its not an emergency, its only an faulty indicator, the elmnt is not actually heating
Mar 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven and Stove top don't heat up but indicator lights on
there may be power but is it enough power??? if electric oven oid check you fuse box/ circuit breakers and physically reset the double breaker controlling the stove, perhaps one leg of power has dropped out
Mar 17, 2008 | Ovens
GE Stove:
The symptoms suggest that the control relay has welded contacts. This was a result of the element failure producing a surge of current. You will need to replace the electronic control. Another possibility is to contact the folks at www.cgiltd.com.
They offer a repair service.
Jan 22, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
191 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
