Question about Canon PIXMA MP780 All-In-One InkJet Printer
How to set up network printer sharing using Vista for my MP780 Cannon printer.
    Sergeant:
  • 324 Answers
After installation on the SERVER(ie the system where the printer is being installed), all you have to do is to right-click on the printer icon and share it, then locate the the server on the workstation(the other systems you want to share the printer to) and connect
Posted on Sep 09, 2009
How to I set up my dell laptop in my house to print wirelessly from a canon mp780 printer?
Basicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.
Mar 25, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Tip
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA With three different...
With three different versions of Windows being used now, you’ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines.
In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version).
Set Windows 7 Share Settings
On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter.
Then click on Change advanced sharing settings…
Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles.
Depending on your setup, you might want to turn off password protected sharing. Other wise you’ll need to enter the password for each machine in, which isn’t that big of a deal. Turning it off while you’re setting it up makes things a bit easier though by saving a step.
Set Vista Share Settings
On the Vista machine we need to double check and make sure it’s sharing settings are ready to go. Right-click on Network and choose Properties.
The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery.
Also on the Vista machine you might want to turn off password protected sharing … but it’s completely up to you.
Share Files Windows 7 View
Now that we have the correct Settings On each machine, it’s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC.
There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared.
Share Files Vista View
Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it’s MYSTICGEEK-PC).
I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting.
Then you’ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available.
And you can continue browsing through all available shared folders and files.
Printer Sharing
As we showed above, you can see the printer connected to Windows 7. Let’s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter.
Right-click on the shared printer and select Properties.
Under the General tab click on the Print Test Page button.
The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine.
Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer.
Provided everything prints out successfully you might want to make it the default printer.
Troubleshooting
If your machines aren’t able to see each other or the printer isn’t working…here are a few steps you might want to use to determine where the problem is.
Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above.
In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer…
If the printer isn’t working, double check to make sure you have the latest drivers for each OS installed.
on May 24, 2010 | Computers & Internet
Tip
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
on Jan 18, 2010 | Office Equipment & Supplies
Can i connect my canon pixma mp780 using wireless feature?
The specifications for this printer reveals it has no network capabilities at all.
You can connect this printer to a computer and set it up as a shared printer and if you have a wireless router connected to this computer and printer then you can print from a laptop using a wireless connection.
Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
Can't connect Xp laptop to 64Bit Vista PC to be able to print across wireless network
yes easy to fix, just share your print driver give it a share name like canonmp780 on the pc it is connected to
then get on your laptop asuming its on your wireless network and in the start bar run this command. \\ your computer name one printer is connected to \ canonmp780.
so if your computer name is windows and your printer name is canonmp780 the run command will be: \\windows\canonmp780 hope this helps and really easiest way to connect to it.
Canon tech
Apr 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Sharing cannon printer MP170
If you want to make your printer a Stand-alone device (no need to be connected to a computer, just directly to the router) you may want to look at getting a Print-Server.
But if you just want to share the printers, you will have to install the printer separately on both computers (since they use 2 diff drivers for the printer), then share it on the vista computer. at this point you should now be able to print on both machines
Nov 24, 2008 | Office Equipment & Supplies
Setting up a new computer on a wireless network
hello Danj29,
I suggest you make sure that your Vista is configured to connect to a private network. To do this follow these steps:
1. Click Start, right-click Network, click Properties.
-The Network Sharing Center window displays the network type in parenthesis after the network name.
2. To the right of the network name and type click Customize.
3. In the Set Network Location dialog box, click Private, and then click Next.
4. In the Successfully set network settings dialog box, click Close
By changing your network location type to private, network discovery is automatically enabled in the Sharing and Discovery section of the Network and Sharing Center window. The following additional file and printer sharing options must be manually enabled:
  • File sharing
  • Public folder sharing
  • Printer sharing
  • Password protected sharing
When all of these sharing and discovery options are enabled, your computer can:
  • Locate other computers and devices on your home network and have other computers locate your computer
  • Share its folders
  • Share its Public folder
  • Share its printers
  • Require user names and passwords for other computers that connect to the shared folders and printers of this computer
To enable file sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to File sharing.
  2. Within the File sharing settings, click Turn on file sharing, and then click Apply.
To enable public folder sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Public folder sharing.
  2. Within the Public folder sharing settings, click one of the following:
    • If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    • If you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
  3. Click Apply.
To enable printer sharing and share all of your connected printers, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Printer sharing.
  2. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
[Optional] To enable password protected sharing, do the following:
  1. In the Sharing and Discovery section of the Network and Sharing Center window, click the down arrow next to Password protected sharing.
  2. Within the Password protected sharing settings, click Turn on password protected sharing, and then click Apply.
Hope you find this helpful info and thanks for using the FixYa service
Kind regards
Feb 14, 2008 | Computers & Internet
Drivers
download it from the cannon web page or let windows vista look for the drivers on the internet
Nov 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Drivers for Vista
you can get it on the cannon web page or let windows vista look for the drivers on the internet
Canon PIXMA MP780 All-In-One InkJet Printer Logo
51 people viewed this question
old marine
old marine
