Question about Boating
Cant get choke to operate on C50TLRY 2000 50 hp 2
Cant get choke to operate on C50TLRY 2000 50 hp 2 stroke. cleaned carbs, idles good, have to hold hands over carbs to start and to accelerate onto plane. Motor seems to run well once some rpms are gained.
Thanks Tom
  • 11,896 Answers
Check choke itself to make sure it moves freely. Adjust the cable and spring if necessary. If the choke is controlled by a vacuum controlled actuator, make sure it is not leaking or loose pressure
Posted on Sep 09, 2009
How to Adjust idle circuit? Why does it start, but does not keep running.
2 stroke or 4? if 2 stroke definitely jetted wrong choking makes it rich tells me your main jet is too lean (smaller hole) you need to pull carb check jets for plugage clean jets write down numbers check dealer for correct jet size for your elevation if 4 stroke back fire thru carb indicates timing is off or bad intake valves or cam lobe worn
Oct 03, 2016 | ATVs
If a 2 stroke dirt bike wont idle and the jets are clean what could be wrong
If it is older bike the reeds in the carb could be bad or going. Might what to check out the choke also.
Feb 14, 2016 | Motorcycles
Not running
I would check all of your fuel delivery system first. Make sure your gas line at the motor end has pressure and that you haven't hooked up the hose in reverse ( it happens). If fuel squirts out when you push in the little ball with a pointy object, you're good. Next, I would check the screen /filter on the fuel pump and maybe clean up the screen with a little carb cleaner. If it was running good last time you used it, the last thing I would mess with is the carb.
Apr 20, 2014 | Light Outboard Motor Boat Bass Fishing...
Mariner 28hp only wants to run on choke ,will not idle
Suggest you clean carb with a good 2 stoke carb cleaner,also check float level,with carb upside down should be parallel to carb body
Oct 07, 2013 | Seloc Mercury Outboard Engine Repair...
I have a problem about my bike and i need advice if you can help me...
Hi, Sasa sounds like you have water in the fuel system drain and flush your gas tank, remove carburetor disassemble and clean and repair the choke for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How to Clean 4 Stroke Carb Part 1
How to Clean 4 Stroke Carb Part 2
Suzuki RM Z250 Owner Service Manual
OEM parts for Suzuki
Suzuki RM Z250 Owner Manual
Mar 31, 2017 | 2011 Suzuki RMZ250
No idle,only runs if choked
2 and 1/2 just a point of refrence, it might have just as well been 1 1/2, when cleaning carbs disasemble them,as just using spray or add to the tank cleaners cant remove solids stuck in carbs and filters.Also look for any damage to ductwork at carbs that could let in any unregulated air.
Apr 11, 2010 | 1999 Suzuki GSX 600 F (Katana)
250 Polaris Trailblazer wont start- new spark new filiter help
Did u choke it ? -stroke are very cold blooded Mine(2003) needs a choke after sitting 1/2 hr at 70 degrees.
Mar 31, 2010 | Polaris ATV
J.D snowmobile 340 73 carb wont idle appears internally clean.
I would have your compression tested, if its a two stroke, and you can use tools with out breaking things or yourself, pour a cup of fuel down the left hand side of the carb and take the right hand side of the carb off and crank it like mad, if fuel leaks from there you better get to a repairer.
other wise the idle adjuster is usually on the left hand side where the accelerator linkages are, it will be a screw where the linkage touches when the throttle is closed. not too hard to find if you have a light source.
Hope this helps.
If you want any more help just ask :)
Feb 07, 2009 | 1987 Honda NSR 250 MC 16
Wont stay running with out the choke on
it sounds like you need a carb clean performed. the idle cuciut jet is probably dirty and that is the jet that supplies gas to the combustion process at idle rpm's. when you have the choke pulled out it is adding fuel and air so when you shut off the choke the fuel supply goes away. for the oils use yamalube 2 stroke oil for pre-mix and 10w -30 gear oil for your tranny.
Dec 17, 2008 | 2003 Yamaha YZ 125
I have a Yamaha EF1000is Inverter/Generator. I am having trouble with the idle speed when the choke is all the way in. It chokes itself out. What can be done?
Not sure exactly what you mean but here is what I know:
1 - You shouldn't have to use any choke at all once the engine has started and warmed up, if you have to apply some choke to get the engine to run correctly then you have a carb problem. Clean and service the carb and see if that makes it all better.
2 - The idle speed is set by a small screw on the body of the carb itself, if it's set too low the engine can shut off rather than idle. Make small adjustments until you get it right.
3 - Dirty air cleaners can cause problems with idle
4 - fouled and/or misgapped spark plugs can cause idle problems
Please rank this answer,
Carl
Dec 02, 2008 | Yamaha 2500 Watt Industrial Inverter...
Boating Logo
235 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
