I wish to know the capacity of this drive - Computers & Internet
  • 1 more comment
  • mwillie65 Sep 09, 2009
    ACOMADATA HD75QUHE5-72
  • ikkenom May 11, 2010
    Exactly what manufacturer and model-number do you have? When you connect it to your computer, and then open "My Computer", and then click with the RIGHT mouse-button on the icon for the drive, and then choose PROPERTIES, what is reported?
  • yadayada
    yadayada May 11, 2010
    what drive??
    President:
  • 2,600 Answers
By the way that model number is spelled out it looks like an 80GB with approx. 75gb available for use.
Posted on Sep 12, 2009
I have Pen drive of 8gb. it has any folders and virus has hidden some files from folders and some are visible. I Have Rum CMD command and attrib -h -r -s /s /d h:\*.* but C:\Users\Khurram...
Hi there, you need not to put anything further on that drive. Many drives sold are fakes, i.e they are purported to be a particular capacity when they are hacked devices that are not the stated capacity. If your drive is one and you have exceeded the actual/real capacity the drive will have overwritten some of the data that was previously stored on it.
You need, before doing anything else, to download and install H2TESTW V1.4 this is described as the gold standard software for testing electronic storage devices. It is free.
Install it and run the application, when the test has completed you will find out whether the true capacity of your device is 8gb and whether a virus has infected it or whether the device is less than 8gb. If the device is 8gb and the presence has caused the effects you describe a data recovery process can begin.
I wish you the best of luck
May 17, 2015 | SanDisk Electronics - Others
Tank capacity chart
Fuel Tank. 17.0 gal, Good-Day!
Aug 10, 2014 | 2003 Chevrolet Monte Carlo
I wish to know what volume of engine oil and what volume of gear oil
Check this out: http://www.motorcycle-usa.com/26322/Buyers-Guide-Specifications/2011-KTM-530-EXC.aspx
Typically, in a 4 stroke engine, the engine oil and transmission oil is the same oil. I don't know but would estimate the capacity to be about 2 quarts. Do not over fill. How will you know? Is there a oil dip stick on the side of the engine? I think so. After you drain the used oil and replace the plug, put in 3/4 of a quart then check the dip stick. Use the quality of oil recommended by the manufacturer. Continue this process until you reach the full line on the dip stick. Is there no owners manual that came with yor motorcycle???
Feb 15, 2013 | Motorcycles
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    Component details
    ZENITH NOTEBOOK, Z-NOTE 425Ln+, CPU 80486DX 25MHZ, 8MB RAM, 1.44MB FLOPPY DISK DRIVE, 200 MB HARD DISK DRIVE, 9 PIN SERIAL PORT, 25 PIN PRINTER PORT, PS/2 MOUSE PORT, VGA MONOCHROME VIDEO LCD, EXTERNAL VGA CONNECTOR, AC ADAPTER, WEIGHT 8 LBS,
    You can install Windows 95, I'm not sure about Windows98
    Aug 25, 2009 | Computers & Internet
    Memory space
    acer laptops have 2 memory hole. you can use 2 x 2gb total 4 gb. but in XP you can see only 3 gb with Service pack 2. in vista you can see all 4 gb.  hope its you need. pls rate
    May 28, 2009 | Acer Aspire 5735 Notebook
    Maximum HDD capacity of an ACER Travelmate 212 TX
    Yes you can install a 20 Gb hard drive but I doubt you can buy a new one with that small capacity. The smallest capacity hard drives are approx. 80 to 100 Gb or greater.
    You most likely can buy a 2nd hand drive but you don't know its quality, it may have had a hard working life and you don't know how long it will last, but then, if is very cheap that may not be a problem.
    Mar 31, 2009 | Acer Computers & Internet
    Wish to install new hard drive in my Dell Dimension 9150
    The BIOS can sometimes be a limiting factor when upgrading to a larger drive so I would check if you have a flash BIOS that can be upgraded to accommodate more memory or larger drives. The utility used for upgrading would have to come from Dell's website.
    To characterize your system in detail, I recommend using Belarc Advisor:
    Belarc site
    Mar 26, 2009 | Dell (2336V) Motherboard
    Computers & Internet Logo
    27 people viewed this question
    David Payne
    David Payne
