Question about KitchenAid KGRC608LSS Gas Kitchen Range
KitchenAid Gas Range Temperature Probe
Hope someone can help,
The electronic display on our Kitchenaid Gas Range is stuck in the "Temperature Probe" mode. It's asking us to enter the probe temperature, eventhough we don't want to use it. We tried unplugging the stove hoping it would reset it, but no luck. Does anyone know the solution?
Thanks in advance,
Brian
  • 3 more comments
  • TIGERINCOURT Dec 23, 2007
    I have the same problem. please help.
  • Anonymous Jan 28, 2008
    same problem -- it wants me to set Probe Temp, but we don't even HAVE a probe -- it won't accept any number I give it, turning off power at the circuit panel didn't reset it -- can't use the oven, and it keeps beeping. Answer please?
  • bigfamily Jun 12, 2008
    no solution, but I have the same problem. I have had the control panel replaced 3 times since Dec of 07 and eventually the probe light comes on tellling me to set hte temp or take the probe out. Too bad I don't use the probe!
  • coronadoca1 May 11, 2010
    I received the 'insert probe' message on Thanksgiving, after I had cooked the turkey, but before the side dishes were baked.
    I have never used the probe and had no idea where it was, so I found the probe hole and inserted a long wooden toothpick wrapped in a wet paper towel and turned it around a few times. That did the trick! Now I will clean my oven!
  • Wendy Sep 03, 2013
    Goodness, this is exactly the same problem for me too. Anyone out there can help? Did all that, unplug, wait and.......no use.
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Posted on Jul 04, 2009
  • Jack Ing Dec 31, 2013
    problem is...I have NO Porbe Jack in the oven
There is a "normalling" contact in the jack the lets the oven know you plugged in your probe.
Infrequent use of the probe, allows a film to build up on the contacts, fooling your oven to believe the probe is inserted.
As these contacts are self cleaning though use, all you need to do is plug your probe in and out several times and it should work fine.
Don't, plug anything other than the probe into the jack, as you might bend the leaf contacts inside and it wont work.
Posted on Nov 27, 2008
    I have No probe Jack in the oven
This is similar to above solutions, but may provide deeper cleaning, and worked for me. Try inserting a wooden food skewer deep into the jack, and carefully rotate it around to clean the jack. Careful that the skewer doesn't break off, though.
Posted on Sep 14, 2008
    I have No Probe Jack in the Oven
    New Friend:
    Problem Solver:
  • 9 Answers
This happened on our Kitchenaid electric stove/oven as well! I unplugged the oven, opened up the outside panel of the oven (same side as the temp probe jack) and found a small metal tab adjacent to the jack. I opened that up to reveal the jack surrounded by moist fiberglass sheeting. A boiling pot of beans had over-flowed on that side of the range the day before. Moisture had gotten down in there and was crossing the connections. Once I dried off the exposed metallic parts and moved the moist fiberglass away from the connections, problem went away. Hopefully, a good self-cleaning cycle will dry up that moisture.
Posted on Oct 04, 2013
  • UCanDoIt May 12, 2014
    If you have this model, you have a probe jack. It's a hole that looks like a set of earbuds could plug into. Sounds like you may need professional help.
    New Friend:
    Problem Solver:
I had this problem with the oven displaying the probe symbol even when no probe was inserted and asking to set the probe temp. I removed the side panel and disconnected the leads to the probe socket. Problem fixed, I don´t use the probe anyway. It seems to me that the probe socket had a short and if I wanted to use the probe I would replace the socket.
Posted on Dec 13, 2014
Hi all- I too had the same problem. Believe it or not I used my IPOD ear nubs/phones. I only used the RF connector piece. I took off the plastic then stuck the headphone jack in where you would connect the meat probe and problem solved. I hope this helps
Posted on Jul 04, 2008
We had the same problem. I plugged in the probe and took it out a few times to possibly clean the probe contacts, and so far (two days), the problem has gone away.
Posted on Jun 29, 2008
Our KitchenAid Model KERC607 always has the symbol for temperature probe on the display, thinking the probe is plugged in, and pressing "Cancel" does nothing to remove the symbol. We don't even own a...
this obviously not an isolated problem.
Go here and see what they have to say...
http://www.applianceblog.com/mainforums/kitchenaid/12867-kitchenaide-issues-temp-probe.html
Here is good information about appliances. Why re-invent the wheel
Sep 28, 2010 | KitchenAid KERC607 Electric Kitchen Range
Controls lost mind -- keeps asking for probe temp
Houston, we have a problem... Your electronic relay control, (ERC), is shot, kaput, no bueno and must be replaced in order to correct your situation. The ERC part number is 3191106, and retails for ~305.00 dollars! (I kid you not). I guess now is the time you might consider replacement over repair. That's a good question. If you choose to proceed with the repair, repost and I'll help with details on how to do it.
Aug 10, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Our oven door is locked and giving a too hot warning. It is not too hot. Error codes f5 e7 and f3 e2 have been displayed. unplugging it does nothing. We have a kitchenaid thermal-convection gas range
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 11, 2009 | KitchenAid KGST307 Gas Kitchen Range
Probe indicator beeping. Can't turn off.
there is a continuous beep on my oven and it says enter the probe temperature. I never used and would like to cancel...how?
Oct 09, 2009 | KitchenAid KGST307 Gas Kitchen Range
Temperature probe in Kitchenaid YKEMC308 stopped working
4455636 sensor, 4451442 thermostat 4450812 thermostat controller, could be all three, I usually start with the controller over 80% of the time thats it
Nov 30, 2008 | KitchenAid KERC500 Electric Kitchen Range
Set probe temp or remove probe
my oven keeps telling me to input a temp probe and it keeps blinking and its getting on my nerves.
Jul 13, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid gas oven
the Controller is asking you to set the probe temp because it thinks the probe is plugged in try to plug in your probe and remove it and see if it goes away if not the probe outlet is bad or if it flashes a code i will need to know that ..also you went into the Factory Version not the Error codes menu an error code would read like a F7 or F2 just an FYI
Nov 22, 2007 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
KGRT600HBL
I couldn't find an exact match for your fault code, but nearly every range fault code of F7 that I have experienced means you have a defective Electronic Range Control (ERC). This the electronic computer with clock and timer. The circuit board is usually not serviceable and has to be replaced. Usually an expensive repair. Sorry...I hope this was helpful in some way.
Jul 04, 2007 | KitchenAid KGRT607 Gas Kitchen Range
KitchenAid KGRC608LSS Gas Kitchen Range Logo
4,828 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
