Question about D-Link DIR-625 (790069292637) Wireless Router
Port forwarding with DIR-625 (wireless environment)
Connecting to the internet via a DIR-625 router, using the wireless G to do the job; however, ports are blocked even AFTER I followed the instructions to port forwarding and even setting my laptop to the DMZ. Thanks.
    Master:
  • 441 Answers
Does your modem has a NAT too? if not then upgrade the firmware of the router that usually fix the problem, if not then ask your ISP and see if they are blocking the ports. have you tried connection without the router to see if that will work?
Posted on Sep 10, 2009
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Dec 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do I initiate port forwarding on my dir-625
check the ip address of your router, you should do fowarding on the settings of your router.
You should open a port number not the same with an application on your computer. If we have counter strike which has a 1809 port number, then you shouldnt use that port number because its being used by counter strike.
Aug 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
Jun 06, 2009 | D-Link DIR-625 (790069292637) Wireless...
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have installed 2 delink routers for my Mac, I still cannot get on line. the mac is new, what is the problem?
Try to configure the DIR-625 wireless router. Connect your computer to one of the LAN port to one of the router. Then access the IP address of the router (192.168.0.1) configure as dynamic IP then clone the MAC address. Make sure that you modem is connected to Internet port section of the router. Check the Internet connection after the configuration leave the other behind check the connection of the main router before installing the other one.
Mar 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
DLink DIR-615 can forward ports
You probably have a 3rd part firewall software on the PC, configure that firewall to allow the same ports. what AntiVirus do you have?
Jan 15, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
206 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
