Question about Hitachi 50VS810 Television
I have the lamp,the tv is still not coming on. Is there something that has to be reset?
  • 11,896 Answers
Yes. You will have to reset the lamp hours. It should be in your owners manual.
Copy and paste this link in your address bar if you don't have the manual:
50VS810
http://tv.manualsonline.com/manuals/mfg/hitachi/hitachi_projection_television_product_list.html
I have heard that this may work on your tv
1. Switch power ON, and press the TIMER button on the remote control transmitter, or the RESET button on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote control transmitter, or the RESET button on the control panel, while the lamp timer is displayed. The 'LAMP xxxx [] -> 0 [|] CANCEL' message will then appear.
3. Press the [<|] and select 0, and wait until the timer display is cleared.
Posted on Sep 09, 2009
I just replaced the lamp in my Hitachi 50vf820 tv and it comes on for a second then cuts out and blinks red temp light.
Make sure all the fans are working correctly. If the problem persists then it might be the ballast, the power supply or a bad temp sensor.
Mar 26, 2014 | Hitachi 50VF820 Projection TV
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
TV WILL NOT TURN ON . LAMP LIGHT COMES ON. IS LAMP BAD OR CAN IT BE THE BALLAST OR SOMETHING ELSE.
The Lamp light of the TV blinks when the Lamp in the TV requires replacement.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, re
If the issue persists, the lamp requires replacement. The Lamp model # compatible with the TV is XL-2100U. View page # 13 of the manual. View page # 2 of this manual for the information about the lamp.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 12, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Hi, i changed the lamp on my LG LCoS Projection TV Model 71SA1D. Everything was great for about an hour or so. The lamp warning indicator reappeared and the TV shutdown only to come back on within a minute...
it may be something with the new lamp or the projector overall. try to turn it off, disconnect the power cord, press the power button for about 10 seconds, remove the lamp and reconnect it making sure it is properly installed. then place the cover securely and try to test it again. you may also need to reset the lamp time for it, refer to the manual of your device for the instructions.
Dec 26, 2010 | Televison & Video
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
Feb 09, 2010 | Mitsubishi WD62327 TV
I have a Samsung HL-S4676S projection TV and the lamp light on the front blinks several times before turning off. Is this a lamp issue or something else?
remove lamp. put in your freezer for 5 minutes. reinstall. when unit comes on, go to menu lamp setting and reset it to zero hours
Nov 11, 2009 | Samsung HLS4676S Television
Wont turn on and lamp has been replaced.
You most likely have to reset the lamp timer. If it gets maxed out it will not turn on till it is reset. Check your manual to see how to reset.
Sep 12, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Red lamp light comes on. do i need a tech or can i replace
You will be able to do it your self.. On the back of your tv there will be a door held in place by philips screws. Take the door off and then the lamp is secured by a few more coin screws( a nickle works). Remove them and remove your lamp.. Install your new lamp be very carefull not to touch your bulb. (it causes premature bulb failure..due to the oils on your skin) put all the screws and door back on (will not operate without the door) plug it in wait the 90 seconds for mitsubishi to reset then your done.. here is your lamp part number
915P049010
Mar 16, 2009 | Televison & Video
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Open Questions:
See all Hitachi 50VS810 Television Questions
Televison & Video Logo
173 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
