Question about Vacuums
Panasonic MC-V5258 Upright has been turning off after about 5 minutes of use for several months. It has been taken into the shop where it was bought at least one time and evidently it wasn't fixed. I think the warranty is out. I paid $438.00 for it! Linda in San Antonio Texas
  • 430 Answers
Lind a, I don't recall if this unit has an overheat sensor. Try it again and if it shuts off see if the vac feels very hot, but do not touch the switch, leave it in the on position, to cool down. When a vac overheats it will generally restart on its own in about 20 minutes if it has a heat sensor on the motor.
If your vac restarts, you either have a defective sensor or a blockage in the hose or filter area causing the motor to overheat.
If it does not restart your problem is electrical, sticking carbon brush on motor, bad cord, etc.
Post back with more info
Posted on Sep 10, 2009
HOW TO CHANGE A BELT ON A MC-V7305
Make sure vacuum is unplugged. Lay. Vacuum upside down and remove Bottom plate. Pull brushroll from nozzle housing, pull metal end caps from brush and remove any hair and debris. Put new belt around motor shaft then around brushroll. Put one hand on each side of belt and pull brushroll to stretch belt far enough to drop brushroll into position. Make sure brush spins freely. Install bottom plate. Make sure brushroll turns freely, if not, make sure bottom plate is not restricting the belt before you turn the vacuum on. Repeat the process in 6 months. You may be surprised to see how much a belt stretches and loses elasticity after it's been on your vacuum for 6 months.
Feb 08, 2015 | Panasonic Vacuums
WHERE DO I FIND A REPLACEMENT BELT FOR MC V7305
Any Vacuum shop should have this, and depending where you live, canadian tire, walmart, target, Sears should have the belt.
If your not close to any of those places, let me know and I will try to help out better.
Good luck,
Mark
bartmkh@yahoo.ca
Nov 07, 2010 | Panasonic MC-V7305 Upright Vacuum
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Panasonic upright vacuum MC-E458
Sounds like a problem with the impeller. It is loose or broken. It is attached to the motor shaft.
Mar 10, 2008 | Vacuums
Can not find a new brush
You should be able to order thru a repair shop, you will need your model number. Are you talking about the brush roll or an attachment brush?
Jan 05, 2008 | Panasonic MC-V7720 Bagless Upright Vacuum
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
