Maytag Neptune MAH5500B Front Load Washer Logo
Anonymous Posted on Sep 09, 2009
The agitator became very noisey (clicking sound) and then stopped
I have a Admiral Model # AAV7000AWW
While running, the agitator became noisey with a sort of clicking sound which became louder with the spin cycle. During the rinse spin cycle I heard a loud click or bang and then the washer stopped working completely.
Marvin
Level 3:
Top Expert:
  • Maytag Master 85,242 Answers
  • Posted on Sep 09, 2009
Marvin
Maytag Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024019
Points
266281
Sounds like the washer transmission has failed.
Testimonial: "Thank you for answering my question so quickly. I didn't like the answer (bigger problem than I was hoping), but it was very helpful. "
Admiral AAV7000AWW washing machine - Agitates during spin cycle, but machine does drain?
Your washing machine top lord or front lord?
If your washing machine top load you have cleared drain valves in have blocked then check drain motor like that as you can check which model or type
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
Admiral washer aav7000aww-agitator only spins one direction-doesn't agitate-it stirs the laundry.
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
Here is the transmission to order if you should find it bad.
6helpful
Admiral washer will not agitate or empty it is a aav7000aww,what part do i need
What you need is a motor coupling, either take of front panel if it's on this model or take the whole cabnet off. To do this, take two screws off either side of the back near the timer. Then lift timer console upwards, you'll see two metal clips, get a flat head screw driver pop both and unplug lid switch. Remove cabnet, and the motor coupling is right behind the motor.... It will cost about 29.95 plus tax for the motor coupling give or take
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Admiral washing maching model aav7000aww
Hello donerehart
You said, water and spin cycles are fine, but won't agitate... what can i do?
Sounds like the timer in the dial will not progress!
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
