Question about HP LaserJet 2840 All-In-One Printer
Format problems using doc feeder
Same problem here. Using the feeder on top wil not scan full A4 format paper. No solution so far.
Software scans by Adobe didn't fix this, hope new firmware does
Scan streaks with HP LaserJet Pro 200 color MFP M276nw
This may not always be the solution, but in my case it was. If you are getting black streaks on your copies, try this first:
The problem is that that there a small piece of glass that the doc feeder use's to scan the original. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out or other residue, on the glass, just clean with a monitor wipe or take a cloth & wipe, etc...... Good Luck
Online tip from Chris Coughlin, but I changed a few of his words.
Feb 05, 2013 | HP LaserJet Pro 200 color
How do I scan multiple pages per file on my HPJ6480 without using HP Solution Center Software?
Windows XP Follow these steps for the Windows XP operating system. Scanning with Paint To scan a document using Paint in Windows XP, follow these steps:
NOTE: Before you begin, make sure that the product is connected to your computer.
  1. Click Start , point to All Programs , point to Accessories , and then click Paint .
  2. Click File , and then click From Scanner or Camera .
  3. Make any desired setting changes.
  4. Click Scan .
You can put the scan to do docs in the upper paper feeder and press the scan button.
Dec 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan to a word doc? I hit scan and
How are you connecting the all-in-one to the computer? Do you have the full-feature drivers/software loaded? (If you use a USB hub, try being directly connected to the computer. The buttons are sensitive to any intermediate connection that might block bi-directional communication.) Can you scan from the software on the computer? Check the cables and ports.
Once you scan the document, you need to run the OCR software to convert it to a document format for your word processor. (HP sent a version of the I.R.I.S. OCR software on the included software disc.) HP recommends using WordPad (which comes Windows) as a intermediate before going to a full-featured Word Processor.
I hope this helps.
Mar 16, 2010 | HP J4680 Office Jet All-In-One Printer
Not scanning full page
You omitted some details which might help diagnose the problem. For example, are you using the document feeder or the flatbed? Anyway, I'll take a guess here.
Check your paper size setting and make sure it matches the sheet you are scanning. (Letter, A4, Legal, etc.)
If this is not it, then try scanning from both flatbed and feeder and see if results vary. Note that when you use the feeder, scanning is done in a smaller window to the left of the flatbed, so make sure that is clean.
Mar 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
SHARP AR-507 DIGITAL COPIER
Ckeck the glass on the left side it is about 1inck by 12 inch for white out on it also clean the optics.On your curling problem install fresh paper you can check your fuser temp. in sim 43-1 change it to 180.
Nov 07, 2007 | Sharp AR-507 Copier
Black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Nov 05, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP LaserJet 2840 All-In-One Printer Logo
32 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
