Question about Motorola Mobility RAZR V3
Hello there, My v3 razr phohe is working normally but i can't see anything on the screen? A guy said he would charge me $56.00 to fix it but that is too much. Ihope you won't charge me.should It fell in the water a couple of months ago and came back and is out again.Should i like open the screen and blow inside?
  • hack9109 Dec 10, 2007
    the screen lights up and works properly when you first turn it on but when you close it the screen goes black and never comes on again until you reboot it,
    even if you push buttons you can hear sounds and keypad lights up but no screen and only if you close it, if you don't close it and it goes out you can push a button and it comes back on
  • Anonymous Dec 10, 2007
    my phone has done this before.. the screen is white & i cannot see anything.. i've tried turing it off and on and even taking the battery out and putting it back in & nothin has worked. the screen is still blank and i can't see anything. is there a solution for it?
  • 46 Answers
Doesn't sound NORMAL to me. JK. Try to take out your sim card and turn the phone on. Does the screen do the same thing? If not, turn off and insert your sim card. Turn the phone back on. Is it still reacting the same way? If so, it's the sim card. If not, I guessed we fixed it. If all else fails, open the back of the screen and see if anything is loose.
Posted on Dec 12, 2007
Motorola Razr V3 shuts down during Hello Moto screen. We can't get to any menus.
Does it do this when it's connected to a charger?
Is the battery fully charged up?
Try starting it up with no SIM card. It should boot to "emergency use" screen. If so, then your SIM is bad and you need a new one from your carrier
Jan 19, 2010 | Motorola Mobility RAZR V3
My RAZR *v3* Drains a good battery in 15 minutes
Go to your provider and have them install a current software version for your phone.
Nov 25, 2008 | Motorola Mobility RAZR V3
My Razr V3 is All Charged But The Screen Does Not Turn On!
555 - the flexcable need to be replaced on the phone
guest - flexcable need to be replaced
Oct 19, 2008 | Motorola Mobility RAZR V3
Will no longer charge the batteryh
You have a charging port problem. the part is here ig you need a diagram ill see if i have time to load 1 up. or take it to 1 of these phone guys on craigslist. they wull fix while you wait got like $20.00 if not ill fix it. Merry Xmas
Oct 08, 2008 | Motorola Mobility RAZR V3
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
Jun 29, 2008 | Motorola Mobility RAZR V3
Motorola Razr V3
Severe cold? I have the same problem and that is the only possibilty for failure outside of component. I took the whole phone apart, but did not remove any rf shielding, checked the internal battery, no problems found. Reassembled, and same problem. My
Mar 06, 2008 | Motorola Mobility RAZR V3
Razr V3 wont operate out of the box
Sounds like your battery has dropped a cell
try replacing the battery
Dec 02, 2007 | Motorola Mobility RAZR V3
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
This worked for me - I had to do it several times because I never figured out whether to start with the phone "off" or "on".
Press # * and the "end call (red)" buttons simultaneously and hold for several sections. Then power phone off and back on. I read this was the equivalent of "safe mode" booting for a RAZR. My phone has performed flawlessly since I did this on the 6th of February!
Aug 22, 2007 | Motorola Mobility RAZR V3
Doesnt Turn On
try a new battery fully charged,problem with your charging block probably,had the same problem with my fone and it was the charging block problem.take of the back case, you'll see two screws there ,unscrew them lift the back gently a bit and then screw it back on,will fix the charging problem temporarily or atleast you'll find out where the problem is.gud luck
Aug 02, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
