Question about Nokia 5800 XpressMusic Smartphone
Suddenly my camera on taking photo and video lens
Suddenly my camera on taking photo and video quality seems not clear..with blur effect....i handled with great care...kindly advice ...
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
The photos from my Ricoh Caplio R4 are no longer sharp (they are blurred if anything). Lens is clean & undamaged, I have tried factory reset, new SD card, spare battery (just in case). Thanks in...
you seem to have a similar problem to the one I posted a couple of days ago John. Is your viewfinder image clear before you take your photo? Mine only takes clear shots if I move the sound/movie/camera button up and down a few times and actually see a clear image in the viewfinder before I take a shot. How you cure that is why I posted my query.
Chris
Jan 15, 2011 | Ricoh Caplio R4 Digital Camera
Well i was wondering how i could get a bokeh effect behind a subject? does anyone know? is it possible to do this without a filter?
hello! Yes, you can since the Coolpix L100 has a 15X telephoto lens, you can use the second method described below.
Bokeh is a photographic term used to describe a lens effect wherein the background of the photo is out of focus. This effect is used to blur out distracting backgrounds and give emphasis to the the primary subject of the photo.There are two ways to get bokeh when taking pictures. The first is by using a very large aperture to get a shallow depth of field. You can set your camera’s aperture to f/5 or below. This will effectively throw everything behind your subject out of focus. You can also blur out the background of your photo by using a long telephoto lens. There is no hard rule on how long your lens should be but the longer its reach, the more pronounced the bokeh is going to be.
Dec 25, 2009 | Nikon COOLPIX L100 Digital Camera
Falling image quality
Take a few test shots with the camera on a firm surface or on a tripod. Are they better?
Sep 25, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
Blured photos. Canon Ixus 950IS
Is th camera shake indicator on when you go to take pics? Are you pressing the button half way to allow the camera to focus?
Jun 23, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Fuzzy/ not very sharp pictures
If the photos look pixellated, perhaps you've turned down the resolution/quality setting? Check the manual for how to correct this.
If your photos seem generally hazy, your lens could need cleaning. Use a lint free cloth such as one for cleaning spectacles.
If all your photos have a smooth, out of focus appearance, it could be a camera fault. However, if you've recently been taking photos in poor light without flash, it could also be "camera shake". You can distinguish this from out of focus because the blur is slightly directional rather than being smooth in all directions. Points of light become lines not blurry discs.
Jun 22, 2008 | Samsung Digimax A402 Digital Camera
Pictures are blurry; quality of photos seem compromised
As simple as this may sound, have you cleaned the lens lately? A lot of image quality deterioration comes from a finger print or other smudge on the lens. Digital cameras are succeptable to even the smallest gunk on the lens. Because the lens element is very tiny, use a cotton swab with a drop of lens cleaner (or isopropyl alcohol) to thouroughly clean and dry the lens. If it isn't a dirty lens, check your file-size and flash settings.
May 06, 2008 | Canon PowerShot A95 Digital Camera
Blurred Pictures on Polaroid a500 Digital Camera
Could be:
1. if her hands shake abit while takeing a image that might be it.
2. bad quality selected in cameras settings, read manual for more info on quality setting.
3. lens problem, is it dirty?
if this problem hasnt been here since the day the camera whas bought and none of those 3 work then there might be a hardware issue with the camera, lens damaged? etc.
try takeing a image by haveing the camera sit on a table, then use your pc to check if the picture is blurred.
You can take the camera for analysis to a local electronics or pc repairshop.
Oct 28, 2007 | Polaroid A500 Digital Camera
Nokia 5800 XpressMusic Smartphone Logo
55 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
