Question about Lexmark X502 All-In-One Laser Printer
Laves streaks when making copies but not when printing
  • 298 Answers
Sounds like the glass needs cleaning, also it might have dust or a spec of dirt on the light bar that reads/scans the document. You may need a professional serviceman to come out to clean that. I'd check your owners manual for cleaning tips, also you can check on google for ways to clean a copier thats leaving streaks.
Posted on Sep 09, 2009
Imageclass mf4690 has streaks in copies
Several possibilities: if copying using the ADF - clean the glass under the ADF feed. If a print is the same as a copy - check the toner cartridge. This type of cartridge collects heaps of junk in the waste chamber which interferes with the print when nearly empty. If neither of those - dust on the imaging scanner = refer to service dude.
Jul 28, 2014 | Canon imageCLASS MF4690 Multifunction...
The printer is streaking black streaks through the copies. What can I do to fix this problem?
If printing from your computer prints clear pages with no streaks, then the problem could be due to some dirt on the scanner bed. Grab a moistened soft cloth and gently wipe the scanner glass to clean it. Try to make a copy again.
Jul 12, 2011 | Lexmark X2600 InkJet Printer
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Streaks on faxs sent
Are there streaks on the copies you make?? Print out a report or list from your machine and see if the streaks are on the printed pages.
Open the feeder from the top of the machine...you will see a thin strip of glass maybe 1/2" wide running from the rear of the machine to the front..odds are there is glue/dirt/corrector fluid or some other dirt on the glass. Clean this off..once you can make a clean copy you should be sending clean fax's.
Oct 17, 2010 | Muratec F320 Plain Paper LED Fax
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
My color copies have a black streak on the front and back of each copy. What can I do.
i have an lexmark 6500 all in one copier. If I print from the computer the copies are o.k., however, if I print a copy from the copier the copies have a black streak on them. How do I get rid of the streak on my copies
Nov 11, 2009 | Epson Aculaser C1100 Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Streaks when printing colored copies. I have replaced the cartridges twice.
if its only copies then glean the scanner glass. otherwise disregard this post.
Jul 21, 2008 | Lexmark X83 All-In-One InkJet Printer
Printing is streaking
What exactly did you clean on this machine? Also, when you say it streaks, is it when you're printing or making a copy?
Jun 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark X502 All-In-One Laser Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
