Question about Curtis DVD1045 DVD Player
Player is reading no disc when disc is in tried cleaner same results
Player is registering no disc while disc is in tried several others same results
  • 1 more comment
  • Anonymous May 01, 2008
    dvd reads no disc
  • Anonymous Jun 03, 2008
    having the same problem,disc is in but reads no disc.
  • dmike267 Feb 16, 2009
    I have a Curtis DVD1072 which shows no d after loading. I have a DVD loanded in the player. How do I fix it? Thanks.
Having the same problem ,Disc is in but still reads no disc.
Has anyone resolved this problem yet???
Posted on Jun 03, 2008
Why player won't recognise disc
Several things can cause a disk not to read. You could have a bad disc, the wrong type of disc, the disc might not be finalized, the laser pickup could be dirty Try cleaning with a disk cleaner Other problems include bad or weak lasers the spindle motor could be bad ,the disk in detect switch could be dirty. The disk may not be loading into the proper position.These are the more common problems
Aug 07, 2014 | Nesa Vision NSD-790T Car DVD Player
Update disc read error
1) try to use disc cleaner, and execute for clean the OPU OPTICAL PICK UP, CONTaine the lasser beam and optical system
2) Try again.
3) if the problem persist, you must shure the any disc had been cleaner with special solution in vertical sense NOT in circle, in that way you must erased the information.
4) However if this NOT result, the OPU had been faulty. go to the repair shop TV.
God bless you
Jul 31, 2012 | Panasonic DMP-BD35 Blu-Ray Player
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
It can not read the disc. I get "error no disc" I have tried several, including new.
Try cleaning the laser lens with a either a special cleaner from an electronics store, or a Que-tip with some rubbing alcohol.
Mar 20, 2010 | Durabrand DUR7 Portable DVD Player
Dvd player combo
uncompatable disk?if not try cleaning the lens of the player by using a cd/dvd lens cleaner...the cd thing with the two brushes stuck onto it...with some cleaning fluid
Apr 25, 2008 | JVC DR-MV1S DVD Recorder/VCR
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Toshiba SD-P1400
the lens is bad and need to b changed
Nov 19, 2006 | Toshiba SD-P1400 Portable DVD Player
Curtis DVD1045 DVD Player Logo
404 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
