Question about AEG Washing Machines
Lavamat turbo 1471, stopping while washing - pause light flashing
This washer is in our holiday home and only has done 20 or so washes in it's life. We last used itr a couple of months ago - and today it did it's first wash fine - then on the next one it seemed to get stuck early in its wash cycle. I reset the cycle, switched on & off, and it started and finished fine. We then tried a different wash setting and it stuck again with the Paul/Stop light flashing. Really appreciate any ideas please . Thanks!
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
mediarich
  • 188 Answers
SOURCE: Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid. plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
Posted on Oct 03, 2008
lenwest
  • 150 Answers
SOURCE: F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
Cycle won't start/start light flashing red
Probably a bad wax motor in the door switch or a bad control board.
Yeah you should call someoneif you're not a learned handyman.
Feb 06, 2014 | AEG Washing Machines
I have a new AEG Lavamat Turbo L16850 machine. On delivery, it is entirely dead; no display, lights or anything. I have checked packing bolts removed, power on, fuse changed, door fully closed. Still no...
I have exactly the same problem - but with the additional concern that there was water in the outlet hose & the drum was damp. Who did you purchase yours from? What was the outcome? My machine arrived yesterday evening (Friday) & there's no customer service over the weekend.
Nov 26, 2010 | AEG Lavamat 72640 Front Load Washer
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
20 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
