Question about OKI MICROLINE 320 Turbo Matrix Printer
Trying to print wakeup reports from an avaya switch via IP to 320
I have set up the comm settings, I can get the reports to show on the computer screen but it doesn't print out on the Oki microline 320 turbo. my settings are port 5101, 8, n, 1, no stop bit no flow control. The printer works when connected directly to a computer
Linux driver
Printing via USB:
  1. Get the samsungmfp- repository.
  2. Install samsungmfp-driver (samsungmfp-data will be installed automatically as a dependency).
  3. Go to Administration > Printing and delete previously created printer device(s).
  4. Connect printer via USB.
  5. Once new device has been created, go to Properties and change the Make and Model to Samsung SCX 4521F All-In-One.
For wireless printing:
  1. Connect to your printer. To get the IP address of your printer:
    1. Hold down on the printer power button for about 5 seconds; light will start to flash and when it begins to flash even faster let it go. This will print out the Configuration and Network Report.
    2. Locate the IP address on the Network Report and type it into your web browser.
  2. Once you are in the SyncThru Web Service, go to Network Settings and than to Wireless.
  3. Configure your Wireless Setting through the Wizard and follow the setup process (note that if your SSID contains space your network will not be displayed).
  4. Once the printer is connected to your LAN go to printer setting (Administration > Printing; Properties).
  5. Click the Change button for the Device URI.
  6. Go to Network Printer > Find Network Printer and type in the IP address of your printer.
  7. Apply the settings when it find the PASSTHRU. Device URI should looks something like this: lpd://[IP Address]/PASSTHRU.
Nov 04, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
Password for avaya 4610sw
Talk to your system administrator. The password is set by them and can be anything....
Apr 17, 2010 | Avaya 4610SW IP Phone
One communications with avaya phones :(
Is that a question or a statement? I have Once Comm on a few of the IP Offices, htey work just fine.
Dec 01, 2009 | Avaya 5610 IP Phone
Avaya 5610SW IP is this a voip
Yes it is...
Here is a user guide if you need:
http://support.avaya.com/elmodocs2/ip_office/R3.2/5610_user.pdf
But this set is only good on your network unless you have programming to make the set work outside the network, this is done via VLANS which then the phone can be anywhere in the world so long as they have a high speed internet connection.
Sep 11, 2009 | Avaya 5610 IP Phone
Networked Canon imageRunner 2800 printer stopped printing right
Your modem was almost certainly your router and contained a static IP address for your copier. Check what IP address your copier used to use. In the Printer Properties/Preferences can't remember which there should be a TCP/IP port. What is the IP address for this?
Go into the copier, go to Additional Functions > System Settings > Network Settings > TCP/IP settings > IP address. Turn DHCP off (make sure DHCP box is filled with white). Enter IP address. Press Ok/Enter (if there is a button that says so, can't remember at the moment)
Turn copier off using main power switch on right hand side of copier then back on again.
Does it work? If yes, good.
No, check the IP address of your new modem/router e.g. 192.168.0.1. Is the IP address of the copier in the same range, that is are the first three out of four numbers the same (last number must be different)? If not, change the copier's IP address so that the first three numbers are the same. Make sure the copier uses the same Subnet Mask as the router/modem e.g. 255.255.255.0. For the subnet mask all four numbers must be the same.
May 30, 2009 | Mtd 22" Yard Machine Push Mower
Avaya 4602 hands. Turn on message lamp when a message is waiting.
Do you know which system this phone is on? Is it an IP Office?
If so, chek the manager program and verify that under eachs users tab, ther is a "Vxxx" in the "trusted source" tab. Where "XXX is the extension number.
Nov 11, 2008 | Avaya 4602 IP Phone
HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
Dell 3000cn Network Connection not working
First of, the ethernet must be 'on'. If dhcp available, set it to auto (or dhcp.. anyways..) and let it reboot, just in case :)
if not, try setting the IP-setting yourself. They should be somewhat similar to the settings on your local computer(s).
To add the printer to your computer, select 'Local' printer and specify 'tcp/ip' as which port its connected to. In the new window the ip to the printer should be entered. :) (at least for XP this is..)
Hope this gave you the correct solution..
Mar 18, 2008 | Dell 3000cn Laser Printer
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
OKI MICROLINE 320 Turbo Matrix Printer Logo
117 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
