Question about Samsung HT-X20 Home Cinema 600W Theater System
Burnt out resistor
I have exactly the same problem as Keith - if anyone knows the value of resistor SWR60 on the power supply board it would be a great help.
Many thanks
Jamie
  • 3 Answers
I have put a 1k 1/4w resistor in place and all is working
Posted on Jan 23, 2010
What is the R4 resistor value on the MEGMEET MLT668TL-VM POWER SUPPLY BOARD OF AN E-HOME LCD TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 21, 2016 | Televison & Video
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
Benq LCD Tv Dv3750 PSU model FSP 320-6F01
its better if you replace the whole power supply board rather than replace the burnt surface mount parts because commonly if the surface mount parts burnt out there are some shorted parts that cause that burnt and possibly repeat the problem..
Please rate..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
Burnt out resistor near coils on bestec atx-300-123 rev.c2 no diagram so don't know the value of the resistor.any ideas?
First of all, it is very unlikely that a resistor "burns out" for being defective itself. Usually they are designed to run around 50% of their rated wattag. So they can get hot to the touch but are not over stressed. Therefore, it is more likely that you have something else that caused excessive current to go thru he resistor. So the point is that you can replace the resistor and more than likely it will fail again. You should start with a schematice of the circuit and look for components that could fail in a shorted condition and therefore cause excessive current to go thru the resistor. A schematic will tell you the value of the resistor. I am guessing that it is on a PC board and is therefore "surface mount" style. Look for defects in the board trace causing shorts. A good place to start. Hope you find it. Lots of Luck.
Oct 30, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Burned resistors r319,r320
ampmann,
hi mate, i might be able to help you but i need to know the exact model number and brand of your dvd player.kindly email it to workshop.fungkuei@vanuatu.com.vu
cheers,
markiez23
Jan 15, 2009 | Panasonic Televison & Video
A901 has stopped working
Hello.
first press the boton green inside of the machine, when up the head.
if not working .
then is problems the capacitors and resistors.
Regards
Kenwood Chef Restore
Jan 06, 2009 | Kenwood KM800 Major Classic Stand Mixer
When turn on ht-tz212 it shows protect and turnes off again
I the same problem. When I opened the system up I find that I have a burnt out resistor on the power supply board. Can anyone tell me the value of Resistor number SWR60, which is located fairly central on the board.
Many Thanks
Dec 19, 2008 | Audio Players & Recorders
Samsung HT-X20 Home Cinema 600W Theater System Logo
250 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
