Question about Fuji FinePix S700 Digital Camera
Black/white Somehow I turned the pictures to black/white. How do I get back to taking color pictures?
On the Finepix S700...on the back where the the LCD screen is you have the menu button with the four arrows around it. above the arrows you have the review button on the left and a silver button with an "f" on it. Hold the "f" button down for a few seconds and change it back to color. you have a few options so you may want to read what they are.
Posted on Sep 19, 2009
Testimonial: "Thanks so much! Just the Finepix for Dummies instruction I needed!"
Hi, how do you take black and white pictures on the Olympus µ Tough 3000 ?
you can't shoot in black and white but you can take a picture and change it to black and white.after taking your picture use the color edit option at playback.arrow right or left to choose the picture then press the ok button.use the right and left arows again to select desired color and press the ok button again.this will save a seperate image copy of you original only in black and white.
hope this helps.
Jan 09, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
Need a picture of an already wired T2005
You are placing a pretty tall order here. You want someone to go to a timer that is wired - take a picture of it, transfer it somehow to the computer then attach it here somehow and or draw a diagram ... and for what benefit???? There is a schematic on the door of the switch, at least the dozen or so that I maintain anyway.
There are three termnals in the switch, a common for a white, a hot black and a switched black.
The "line" is the hot black and a white. Your load (white can come to the line white if you want but it is not necessary) a black wire that goes to your light or motor or what ever you are turning on.
If this is a two pole switch (220 V AC) please indicate in your question/response.
If I have misunderstood your question, pleae ask again.
thank you
a
Oct 06, 2009 | Day-Timer Intermatic T2005 Timer SPDT 20A...
Have a sony cybershot, and for some reason it wont take pictures in color, just black and white, and i cant seem to find a setting to change it to color.
put your camera mode in t "P" setting then go to menu & you should see color or pictue options to switch the color back to color....i have a cybershot dsc-w55 idk what u have but try that .... GOOD LUCK !
May 12, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Curtis progressive scan DVD player 1071
your not using progresive scan out are u change that back to regual
Feb 06, 2008 | Curtis Progressive Scan DVD Player 1056
Sony KV-27TW75 Black and White Picture
this is usually due to bad ground check cable line comming into tv and
CHECK/RESOLDER CONNECTIONS IN TUNER WHERE CASING IS SOLDERED TO PCB NEAR 4TH FEED THRU BACK FROM ANTENNA INPUT
Feb 04, 2008 | Televison & Video
RTD 155 - only black and white...no color
Perhaps you have set your DVD player for Progressive Scan Mode while your Television does not support for the same. Go to the setup menu and turn Progressive Scan Off. This will solve your problem.
Feb 04, 2008 | RCA RTD155 System
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Oct 07, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Fuji FinePix S700 Digital Camera Logo
90 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
