Question about Philips VRZ250 VCR
VHS stuck in Philips VR 175 VCR (pal version)
Video is stuck and the player does not seem to recognise that the video is inserted at all.
  • 93 Answers
The most common method is to unplug from the wall,plug it back with your finger on the eject button. if this does not work, then will have to take the top off and tenderly back the wheels or off until it gives you the tape back
Posted on Sep 10, 2009
Tape will not go in all theay
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple ... All Comments (36) ... turning on and off will not stop for a couple minutes then goes off. i turn it ... my vcr/dvd combo set won't turn off, a tape got stuck inside the vcr and it ..... How to Clean a VHS Video Recorder (The Professional Way) ...
VCR First Aid - Sci.Electronics.Repair FAQ
www.repairfaq.org/sam/vcrrx.htm
Dec 13, 2015 | Televison & Video
Can i convert at PAL video with this machine?
The version of the ZV427MG9 sold in the U.S. only supports NTSC video files. Thus it won't play a PAL VHS tape.
If you find a similar version sold in Europe, that would probably play PAL videos. However, if you used the tape to DVD dubbing feature, the DVD would still have the PAL format. I'm not even sure that a video capture device with video conversion software on a computer would do what you want to do.
I wish that I had better news for you.
(The video would also matter. If you are trying to convert a commercial video (ex: a movie) to DVD, the dubbing feature doesn't work due to copy protection.)
Feb 14, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a video cassette stuck in a philips vr 700. The screws are not normal. How do I open the vcr?
You will need a special screwdriver. Depending where you live try searching in electrical parts shops such as Maplin (UK) or Radio Shack (USA). They might be what are called tamper proof screws or something along those lines. You could also try google image search to see if you can try to find the type of screw. Try entering "Tamper Proof screws" first and see if any resemble yours.
May 12, 2010 | Philips VR750 VHS VCR
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
VHS code compatibility
The video standard in Japan is PAL while it is NTSC here in the USA. You should be able to locate a VCR than can play both. If you'd rather not purchase a new VCR, some locations that create DVDs from VHS tapes can usually also read PAL tapes.
Dan
Mar 18, 2008 | Televison & Video
Go Video VR3845 player question
cant play pal on ntsc ok wrong formatt
Feb 04, 2008 | GoVideo VR3845 DVD Recorder/VCR
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Televison & Video Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
