Question about Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna
Samsung Pixon touch screen frozen
Please help!!
I have a Samsung Pixon phone and the touch screen freezes quite often. The call button works fine but the "SOS calls only" appears on the screen even when i've got a full signal.
I have tried taking the battery off and removing the sim, nothing seems to work. It there a reset button anywhere????????
  • mockers2938 Sep 14, 2009
    This solution was not related.
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Posted on Sep 30, 2009
M8800 touch screen frozen
First you need to take out the battery and insert it back on, then you power it on, it should work, after that, you need to calibrate the screen once it is working properly, if not, it will freeze again.
To calibrate the screen, you need to go to the phones menu>settings>calibrate> Then you touch the center of the star that comes up on the screen, after doing it perfectly, the screen will work perfectly fine once again.
There are 2 causes of the screen freezing. 1 is if you have too many large files on your phone, and 2 if the sensor board of the screen is weak, calibrating the screen will solve the second problem or replacing the sensor board if calibrating the screen does not solve the problem.
For the first problem, what you have to do is to assess the files on your phone, if they are too large, the phone will continue to hang because it will be taking longer time to process the file opening. Try to move the large files to your computer or laptop, if not, it might cause further problems to your phone.
That should solve the problem for you.
Jan 09, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsung pixon
Well,the screen has given out, you got a bad phone talk Talk to your fone product supplier and try to buy/get a new one.
May 01, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsung pixon screen is not repsonding to touch
It is a hardware problem in this set... there is one solution I found on the internet...
just follow this link
http://www.handcellphone.com/mobile/forum/screen-freeze
mine is working now
But try it at your own risk
Dec 24, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
My samsung pixon keeps freezing. I can turn it on
This is courtesy of Helifix from Handcellphone.com...
Hello Guys. I have the same problem and I found out the solution. The problem is a faulty contact from the touchscreen leading to the phone board. To be short: on the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something) and see if the touchscreen is responding in anyway. My phone has a bad contact there, and in normal mode all is frozen. Now if I try to pull towards me, the touchscreen frame from the rest of the chassis, only a mm SURPRISE!! My touchscreen is working. IF this is your case too...I suggest get a screw-driver and open the chassis, and trying to make the connection permanent, somehow. I haven't done this yet, but will do it today. If anyone is interested I could post the results:) PS: you can send it back to warranty of a repair phone shop, only to force you to buy a new touchscreen and pay for the repairs, on a 99% working phone, with a faulty contact. The choice is yours:)
Nov 19, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Completely frozen
Hay hay I did it. How I got it to work is thi, pull out the battery on your samsung pixon. switch it back on and continuesly press the ring button. you should get the menu up to ring some one. then start tapping everything. I did this an managed to get the touch screen and the buttons to work!
From Sean
Aug 19, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
My samsung pixon touch screen has frozen
Did you try taking the battery out then putting it back in?
it stops it from freezing
Jul 27, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Touch screen wont work on my Samsung pixon.
I had the same symptons with my samsung m8800 and all i did was squeeze the top right corner of the phone and hey presto it worked agin. I believe it could be a lose connection. hope this helps
My samsun pixon screen is frozen and i cant open anything
phone needs service there might be a problem with the phone internal memory
Jul 01, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsun pixon touchscreen appears frozen
it's a problem with the connection between the touchscreen and phone. the m880 is notorious for it. there's a few quick fixes but they don't last long. take it in to get fixed or buy a different phone, mine is six months old, same problem.
Apr 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Samsung M8800 Pixon - Unlocked QuadBand Cell Phone - 8MP Camera, GPS, 3.2" Touchscreen - Interna Logo
3,281 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
