Question about Logitech 967461-0403-PK Keyboard/Mouse
On the top right of the logitech keyboard there are 3 circles with a 1 -an A - and an underlined down arrow. the first is # lock-the 2nd is Cap lock--what is the last one for? TIA
  • 76 Answers
Scroll Lock
Posted on Sep 09, 2009
  • 298 Answers
Could be scrolldown/end
Distributor cap. Please mark cylinder No.s on distributor cap connection.
STANDING IN FRONT OF CAR.CYLINDERS FACING YOU FROM LEFT TO RIGHT IS 1 2 3 THIS INFORMATION I GAVE YOU FOR THE 3 CYLINDER 993 CC ENGINE. DRAW A CIRCLE ON PAPER WRITE DOWN THE NUMBER 3 ON TOP OF CIRCLE AND NUMBER 1 AND 2 UNDER THREE THATS YOUR DISTRIBUTOR WIRE LOCATION.NOW IF YOU HAVE THE 1295CC 4 CYLINDER ENGINE.STANDING IN FRONT OF CAR CYLINDERS FACING YOU LEFT TO RIGHT IS CYLINDERS 1 2 3 4 DRAW CIRCLE ON PAPER WRITE NUMBER 4 TOP OF CIRCLE WRITE NUMBER 1 BOTTOM OF CIRCLE.ON LEFT CIRCLE WRITE NUMBER 2 AND FROM RIGHT OF CIRCLE WRITE NUMBER 3 THATS ALL SPARK PLUG WIRES LOCATION ON DISTRIBUTOR WHILE STANDING FACING THE FRONT OF THE ENGINE.
Apr 01, 2011 | Daihatsu Rocky Cars & Trucks
My arrow keys do not work and the down arrow key Light is on (that is underlined at the top right of the keyboard). How do I fix this? Thanks
It seems to be a hardware problem and it would be better if you just take it to any technician instead of repairing on your own. Sometime microcontroller in the keyboard went wrong and such happens. You could try working by on screen keyboard if its very urgent to type. If possible try to uninstall our keyboard drivers and then restart the system. after that plug the keyboard again and windows will detect it as new hardware. May be it could work. Good Luck
Mar 28, 2011 | Compaq Keyboard
I changed the spark plugs and wires on my chevy s10 2wd pick up, which is a 4 cylinder and now it will not turn over. I might have the wires mixed up on the distributer cap. Can someone show me a picture...
GET A PIECE PAPER DRAW A LARGE CIRCLE TOP UPPER HALF CIRCLE LEFT TO RIGHT WRITE NUMBERS 1 AND 3 BOTTOM HALF CIRCLE LEFT TO RIGHT RIGHT NUMBERS 2 AND 4 THAT YOUR DISTRIBUTOR SPARK PLUGS WIRES LOCATION.STANDING ON SIDE OF ENGINE WHERE DISTRIBUTOR IS LOOKING DOWN AT DISTRIBUTOR 1 AND 3 FIRST TWO SPARK PLUGS TERMINALS NEXT TO ENGINE. AND 2 AND 4 SPARK PLUGS TERMINAL ON CAP FACING YOU. THIS IS CYLINDERS LOCATIONS STANDING IN FRONT OF ENGINE.RUN WIRES FROM DISTRIBUTOR CAP TO PLUGS TO THE ENGINE SPARK PLUGS.
Oct 17, 2010 | Chevrolet S 10 Cars & Trucks
When on charging craddle the keyboard flashes one time green and threetimes red. and it is not charging properly. what to do?
Be honest have you dropped it? If so you should check the cap under the sleep/half moon key top left button. I was on my 2nd kboard and had the same thing happen as you are experiencing TWO times.
Opend it up and found that a small cap under that key was off, its held on to posts without "real" solder. Logitech uses a cap to bridge these connectors with "wire glue". Its real easy to dismantle and i know they say its a 3 year warranty but they LIE. For the 1st board i "fixed" i used a lump of solder bonded to the 4 posts and bought wire glue for the 2nd keyboard. Its an easy job
May 23, 2010 | Logitech diNovo Edge 9676850403 Keyboard
Plug wires and distributer cap
for the 1.5L -1.6L- 2.2L and 2.3L ENGINES. from left to right engine cylinders is 4 3 2 1 .now at distributor cap .get a piece of paper draw a big circle now at top of circle from left to right will be 2 then 1 from bottom of circle left to right will be 4 then 3.thats where you will put your plug wires.now the circle you draw 2 upper left of circle 1 upper right.at bottom circle 4 lower left of circle and 3 at lower right.
Jun 26, 2009 | 1995 Honda Accord
CLOCK RESET
Press the FN + F9 keys until the time and date appear on the LCD display.
press the FN + F10 keys to go into the Set Mode.
Use the left or right arrow keys to select the hour.
Change the hour by using the number keys on the keyboard or by up and down arrow keys
Use the right arrow key to select the minutes and change the hour by using the number keys or by using the up and down arrow keys Press the right arrow key again to choose the 12-hour or 24-hour format with the up and down arrow keys.
To change the date, use the right arrow key again and use the up and down arrow to select the month. To change the day, use the right arrow to select and the up and down arrows to change the day.
When you are finished, press Enter on the keyboard to exit Set Mode.
hope this helps
Apr 02, 2009 | Logitech Cordless Desktop MX3200 Laser...
Unlock a key
Scroll lock key. On laptops it is usually controlled by a Fn key. Hold the Fn key while pressing the Scroll lock key and it should go off.
Mar 12, 2009 | Computers & Internet
Scroll Lock on -- mystery
On the Logitech LX710 Lazer the Scroll Lock option is toggled by holding down the "Function" key and pressing the "Pause/Break" key. If you look at the P/B key you will see a little orange symbol of an arrow pointing down to remind you of this feature. This can be disabled in the Setpoint panel by selecting Keyboard and Keyboard Inactive Keys then place a check in Disable Scroll Lock so you may have to remove a check mark first.
Jun 25, 2008 | Logitech LX 710 Keyboard/Mouse
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Logitech 967461-0403-PK Keyboard/Mouse Logo
110 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
