Question about Honda Electrical Supplies
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
    Problem Solver:
  • 7 Answers
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Posted on Sep 10, 2009
Honda eb 7000 inverter generator won't stay running. It runs for 12 seconds and stops. I tried disconnecting the oil sensor but no luck.
it appears to be insufficient fuel flow to the carby
check for blockages in the tap , lines , tank filter, needle and seat area
Aug 03, 2016 | Honda Electrical Supplies
I have a eu 6500is generator inverter that will run perfectly for any amount of time, then with no warning just stop generating and idle. No overload alarm. No oil alarm. Nothing will just idle. If you...
this sounds like a capasitor/resistor that is getting hot under load once it is switched off and cools down it works until it gets hot again similar to that of a cars ignition coil which will get hot and cut the vehicle out but once it cools it will start again.
Dec 07, 2013 | Honda EU6500iS Inverter Generator
I have a Honda EB 7000I generator. It runs for 7-10 seconds then stalls. When it stalls the red LED overload light comes on. I just put a brand new Inverter in it. Since it sat awhile with a bad...
As silly as this sounds, Harbor freight toold generators by "Predator" will shut down if the generator is not on level ground, and the oil level is not at the desired level, crazy but there is an inbuilt oil level sensor. maybe this might be the answer. hope iy helps, good luck.
Oct 19, 2013 | Motorcycles
Honda generator
The running on choke is caused by a fuel restriction. Check the fuel flow from the tank to the carburetor.Change the fuel filter if it has one. If its good, then the restriction is in the carburetor. The generator is shutting down due to the low rpm coming from the engine. A carburetor rebuild may need to be done.
Oct 19, 2013 | Electrical Supplies
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
No ac ooutput
your load device problem. some one load device starting load amp high.so find it.
check one by one load connect.
May 27, 2012 | Honda EU6500iS Inverter Generator
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Aims 5000w inverter
Try shutting down the load completely, then power up the inverter with no connected load. Then bring a little on at a time and see what happens.
May 21, 2009 | Inverter AIMS Power 2500 / 5000W
Electrical Supplies Logo
987 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
