Question about Apple iPhone 3G
I can not get my new iphone mini to connect to itunes
I have tried to connect my mini iphone to itunes without success, i comes up on the phone mass storage web cam charging, does anyone have a clue as the manual is worse than useless, i assume its mass storage it open i tunes but then nothing, happens, nothing appears on itunes.
I dont know what to do HELPPPPPPPPPPPPPPPPPPPPPPPPPP
I need to reset my phone amd i forgot my passcode
Hello Karabo, what kind of phone do you have?
If you're an iPhone user and forget your passcode, you will have to factory reset it without Apple ID. To do this you need first put the phone into DFU mode and connect it to iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Restoring iPhone to factory settings with this method will result in wiping all the data. The following steps will show you how to do that.
1. Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
2. After that, turn off you device. Press and hold the Home button for 3 seconds.
3. Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
4. When iTunes detects that your iPhone is in recovery mode, you can restore it now.
5. Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After factory resetting iPhone, you will get all the data swept from iPhone 6 Plus, and you can restore the files from your iPhone, iTunes backup or iCloud backup.
How to Restore iPhone 6 Plus to Factory Settings
Jan 19, 2017 | Cell Phones
I have iPhone 6&6s..form previous owners..how do I start when it asks for ID's and they can't remember
Generally speaking, you need the Apple ID to reset your iPhone. iPhone needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPhone, you need to enter the Apple ID when your iPhone reboots.
But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To do this you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone.
Step 1: Open iTunes on your computer and connect your iPhone to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPhone into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPhone into DFU mode.
Step 4: When iTunes detects that your iPhone is in recovery mode, you can restore it now.
Step 5: Click on Restore iPhone. Then you will be notified after the reset and your iPhone will take a restart.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Dec 21, 2016 | Cell Phones
Forgot password on my old iphone 4s 16gb
It's the most frustrating thing for us to forget our iPhone password. In order to unlock and access your iPhone normally, you need to reset your iPhone password. Resetting iPhone password is not complicated.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
  1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
  2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
forgot-password-old-iphone-4s-16gb-oxaxc0rwhkhzilrwacqreyis-1-0.jpg After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
How to Reset Password on iPhone
Oct 12, 2016 | Cell Phones
How do I reset my iphone
reset-iphone-oxaxc0rwhkhzilrwacqreyis-5-0.jpg But if you have no Apple ID or passcode, you will have to reset your iPhone without Apple ID. To reset iPhone without Apple ID, you need first put iPhone into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPhone without entering Apple ID easily. Resetting your iPhone with this method will result in wiping all the data in your iPhone. The following steps will show you how to do that.
After resetting your iPhone with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPhone, you will get all the data swept from iPhone, and you can restore the files from your iPhone, iTunes backup or iCloud backup. However, you can't backup iPhone to iTunes/iCloud without Apple ID before you reset your iPhone . In this case, you need the third-party iOS data recovery software to help you recover lost data from iPhone after factory reset without Apple ID.
via How to Reset iPhone without Apple ID
Aug 08, 2016 | Apple iPhone 5
I am trying to download photos from my phone to my computer without success.How do I do it?
Hey Robert, what kind of phone do you use?
If it's an android phone, you can simply connect it to your computer with a USB cable. Your computer will then recognize your phone as a camera. Copy and paste, the photo transfer can be transferred at ease.
If you're an iPhone user, here's an official guide to help you import photos/videos to computer. https://support.apple.com/en-us/HT201302
Moreover, you're free to try this iPhone Transfer program as well.
http://www.leawo.org/itransfer/
Jun 22, 2016 | Cell Phones
How to transfer photos from my iPhone 4s to iPhone 6?
Firstly, connect your old iPhone 4S to computer via USB cable and drag photos from "iPhone folder" to an empty folder, you can name this folder "PHOTOS" .
Secondly, launch the latest version of iTunes on your computer and wait your new iPhone 6 to be detected by iTunes. After detection, click your iPhone 6 icon and tap on "Photos" from the sidebar, select copy photos from the folder on computer called "PHOTOS"
Lastly, click sync to start transferring photos from iPhone 4S to iPhone 6.
5 Ways to Transfer Photos from iPhone to iPad Pro Mini 4
Jun 24, 2015 | Apple iPhone Cell Phones
How to fix my iphone 4s without using itunes
I would take to an apple store--there they will know what is wrong--you can try all kinds of other things but your best bet is take it in
Oct 08, 2014 | Apple iPhone 4S
How do I add itunes music to iphone from computer itunes library? Is this possible or do I have to buy all new songs from the iphone Apple Store?
Yes it can, connect your iphone to your computer, at this point as soon as your computer recognizes the iphone itunes should open up.. if it doesn't just open it up yourself. Now on he left where all the playlists are there should be an icon with you iphone there, click on it. Now to the right there should be a tab labeled "music", click on it now you can select wether all your music will transfer over or just certain playlist. There you go.
Ciza
Oct 30, 2008 | Apple iPhone 3G
How to transfer photos from a PC to an iphone
if u r using apple iphone
then folow the steps
install itunes in ur PC and connect the iphone
then select the mode in the iphone
open the itunes application ur iphone will show in that application it means u have successfully connected
drag and drop the songs from my computer to i tunes application it will transfer
Maybe what mentioned above is not useful for you, i personally share you with a article about transferring photos from Computer to iPhone
Aug 09, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
320 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
