Question about Kitchen Ranges
My Garland oven (Model TG3) is beeping with a F5 code. What is that code? How do I clear the code?
  • 84 Answers
We see this code on garland control boards. It means that the control board is not activating the relay. The control board should be rebuilt. It can be done quickly and reliably at www.garland.fixyourboard.com
Posted on Feb 09, 2011
Sir, i have the same problem, did you solved it already?
Posted on Jul 01, 2010
  • 11,896 Answers
If any site has this, it would be this site. I wouldn't know anywhere else except for your company website that could tell you: This site does carry your parts and manual.
http://www.repairclinic.com/0078.asp
Posted on Sep 09, 2009
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
What is F5 Frigidaire oven unit, it's beeping and
The F5 ERROR code means that the self check that the control (also called clock)board runs to check itself has failed and the control has detected a problem within itself and the control must be repalced.
Gene
Aug 10, 2011 | Frigidaire Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
While baking my fridgidaire oven started beeping with the code F5, does anyone know what this means and how to make it stop?
Oven temp sensor shorted.Press and hold any key down to clear and make it stop beeping.
Feb 07, 2011 | Frigidaire Ovens
My magic chef oven flashes F-5 when we try to turn on the oven!
Hi
Thanks for using FixYa. Error code F5 means Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction.
Turn off the Oven for 2-3 hours, the oven will reset itself. However, if the error still persists then follow the procedure to troubleshoot the error code--
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F5 and listen for the beep.
  • If you get the F5 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F5 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 13, 2009 | Ovens
F5 error
HI. I have researched this fault code and this is what we came up with.
F5 Board failure Replace control board (also called ERC or clock).
Mar 21, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Dec 31, 2007 | Whirlpool RF364 Electric Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Kitchen Ranges Logo
309 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
