Question about Husqvarna Chain Saw 20" Bar
My 288 husqvarna wont start - Husqvarna Chain Saw 20" Bar
  • dontbother10
    dontbother10 May 11, 2010
    Make, model and serial numbers help us help you! You must have Fuel (at the carburator), Compression, and Spark for it to run. Do you have all of these? Lou
    Brigadier General:
  • 4,088 Answers
Check for spark with a clean spark plug. If ok, squirt some starting fluid in the plug hole and try to start the engine. If you get a few pops, then work on the fuel system. Check the fuel lines from the tank to the carburetor for kinks, brittleness, or cracks. If it has a primer button, check the button for cracks or hardness and inspect it's lines. Do you have fresh fuel mix in the tank? Make sure the air filter is clean and in good shape. Check the muffler for plugging. If the saw is fairly old, the carburetor may need a re-kit and cleaning. Good luck!
Posted on Sep 12, 2009
What year is my Husqvarna 181SE chain saw. Serial number is 5161420. I purchased it new in the 80's
181 was introduced in '82. The 281 '85 and last was 288 in '88..
Latest IPL found of the 181 is from '84.
Jul 03, 2017 | Husqvarna Garden
How to test coil on husqvarna 288
take spark plug out hold it a millimeter away from head and it should spark or if you like getting shocked then hold the spark plug between your fingers i would not do that because it can kill you
Aug 16, 2014 | Husqvarna Garden
How to replace a kill switch on a husky 288 xp
There should be only 1 screw and one wire connecting the kill switch. The kill switch simply grounds out the ignition. So it is difficult to install improperly. The wire coming from the switch goes directly to the ignition module.
Jun 21, 2014 | Husqvarna 288 Kill Switch Wire Chainsaw...
Setting carb
Gently turn the needle valves in till they stop. Then turn each one full turn out.
Nov 17, 2013 | Husqvarna 288 Kill Switch Wire Chainsaw...
Setting carb
The fuel tank vent is built into the body of the saw. There is a plug cover of the fuel tank vent valve adjustment shaft just in front of the saws handle on the right chain drive side of the saw. Seek a professional.
My husqvarna 288 wont start, has extreme high compresion and cant pull cord with the spark plug in it. easy to pull with spark plug removed
http://www.ebay.com/itm/HUSQVARNA-288-CARB-REBUILD-KIT-COMPLETE-TILLOTSON-NEW-/140290773535 Your carb.may need rebuilt,remove and inspect,did you leave gas in it while it was stored,if so then carb is suspect.About 80.00 for a shop to repair,14.00 for you to do it.
Oct 10, 2012 | Husqvarna Garden
I put a new barrel and piston in my 288 and it seized
Have you used a geunine OEM cylinder and piston. Cheeper aftermarket parts are a waste of money.
Mar 21, 2012 | Husqvarna Garden
Trigger stuck on husqvarna 288 xp lite
The trigger and throttle lock are held with two roll pins, unfortunatly you need to remove the tank from the saw to take them out, i would guess the spring inside has broken.
Apr 28, 2011 | Husqvarna Models 181, 281, 288xp
Protron dvd playerpdv-288
what i wanted to know is were to take the dvd player to have the spring replaced. the telephone number in the book wont go though
Sep 27, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Husqvarna Chain Saw 20" Bar Logo
152 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
