Question about Canon PIXMA MX310 All-In-One Printer
I've got a canon pixma mx310, it just stopped taking paper and said it was jammed, wouldn't print anything, just took paper from one side and stopped. have reinstalled it and now the rollers won't take the paper at all
I have a mx310 and where it feeds the printing paper do not print the printing paper goes to the side and it stops
Looks feeder is broken. Even having the repair kit probably you don't have the technical knowledge to dismount your printer and change the broken piece so you should take it to an authorized Cannon repair shop
Nov 30, 2014 | Canon PIXMA MX310 All-In-One Printer
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
Error message paper jammed on my printer but there is no jam. my color ink is out but i don't use color
when it happen like that turn off the printer, print anything, open the active printing file. it will show u the jam paper and the current printing one. cancel the spoonling paper, after cancelling put on the printer and it will work fine
Sep 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Hello , my name is Bohdan , My printer Cano mx310 jammed the paper, I removed but I steal have a messege 'paper jammed'
hi there bohdan
y dont it do it because there is smill paper in side your printer you have to get it out before you print
again
if you dont came right @ all email on info@jvcomp.co.za
Dec 14, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MX310: misfeeds
Hi Paper misfeeds are normally caused by something obstructing the paper path. Look really carefully both above and below the path that the paper takes through the printer. The jammed paper itself can give you a clue about which side the obstruction is on, there wiil often be some sign, such as a bent corner on the page etc. Also check the sliding guides that keep the paper straight, they should be slid in until they are a snug fit with the paper, but not so tight that they stop it from feeding
Jun 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper Jam!
Clean your pickup rollers with a damp terrycloth towel. What happens is the pickup rollers get lint and dust on them and then don't pick up the paper as well. Cleaning should resolve your issue.
Jun 01, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper Jam!
Hello sir; There got to have something on thr paper path check very carefully, especial at the point of the paper skew.
May 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
