Question about Palm TX Handheld
Have to reset Palm TX to power on sometimes
Lately, when I try to turn my Palm TX on using the "home" button in the lower left hand corner, nothing happens, even after pressing repeatedly. Today when this happened, in desperation I pressed the reset button on the back and THEN it powered on. I don't know if this is related, but I've also been having to hit the reset button often when trying to access the wifi--it connects quickly to a wifi signal, but hangs when I try to use the Palm Blazer v. 4.3 to go onto the Internet. I'm using Palm OS Garnet v. 5.4.9.
  • 47 Answers
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Posted on Feb 13, 2010
Iam trying to remove the owners form a second hand palmOne TX pda
You need to Perform a Hard Reset on the Handheld; 1 Press and hold the Power Button 2 While Holding the power button you need to use the stylus and press and release the reset button on the back of the palm 3 Wait until you see the Palm Logo to release the power button 4 When you see the "Erase all Data" then hit the up on the 5 way button to finish the reset, this will Erase all Data and the Username..
Oct 24, 2009 | Palm TX Handheld
I have the same problem! I use to get on just fine.
Try doing a hard reset. Make sure you have everything backed up on your pc since you will have to do a hotsync once you do the hard reset. OK to do a hard reset do this:
1. Press and hold the power button.
2. While holding the power button, use the tip of the stylus ( or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm2.gif Powered logo to appear, and then release the power button.
4. When you see the message that warns you about erasing all of the info on your hand held do one of the following:
a) Press UP on the 5 way navigator button on the bottom of your hand held to finish the reset and show the touch screen2.gif.
b) Press any other button to do a soft reset.
5. When prompted , tap to align the screen, and then set the language you want to use on your hand held. A screen appears showing the Palm logo and a progress bar. From there continue to set up your Palm and then do a hot sync. You should be able to reset a password if you want one. Best wishes....Hope this helps.
Sep 18, 2009 | Palm TX Handheld
Hard rest plam tx
Here are the steps to do a hard reset. Best wishes.
1. Press and hold down the power button.
2. While holding the power button, use the tip of the stylus (or similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your hand held.
3. Wait for the Palm Power logo to appear and then release the power button.
Aug 18, 2009 | Palm TX Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
I did a hard reset. Now I get stuck either on the initial "Palm P
There is a possibility that there is like dirt or sand between the screen and the frame. I know really simple right? Thats what I thought and it actually was a piece of popcorn for me. Use like a piece of paper or something and try to clean it out then it should take off.
Jun 18, 2009 | Palm TX Handheld
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 17, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
Not turning on
If it's not making the bleep sound when you first connect it, then something is wrong with the connection between the computer and Palm.
Try plugging it in and then while it's plugged in hit the reset button. This resets the charging mechanism inside. Then let it sit a few hours to see if it will come on later.
Also, you may need to troubleshoot the connection from the Palm to the computer. Make sure all is connected securely, make sure the Palm Desktop icon is in the bottom right hand corner of your computer in the system tray.
Dec 13, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm tx power button
1) try a soft reset
2) If that doesn't work, you must go to www.freewarepalm.com to find a power hard button replacer.
Good luck
Pd: my unit has random power button malfunctions too.
Oct 25, 2007 | RIM BlackBerry Pearl 8100
Palm TX Handheld Logo
135 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
