Question about Samsung HLP6163W 61" Rear Projection HDTV-Ready Television
We have a tv turning on then off and states it is overheating
We have a hlp6163wx samsung that when you turn it off it turns right back off and then flashes in read overheating . what do i do to fix it ..
  • 476 Answers
You don't mention if you get a picture or not but you might want to check the lamp for signs of damage. I think you will want to check samsung's website samsung.com/support and type in your model, some of these model are experiencing similar problems and there might be a firmware update for this.
Posted on Sep 09, 2009
    Sergeant:
  • 259 Answers
Lamp fan may have quit running.....located at back of light engine.......have to remove it to replace.......
Posted on Dec 04, 2012
  • 3 Answers
We also have a Samsung HLP6163W.We had the same problem a few months ago. We had to replace the lamp cost us about $140.00. If that doesn't work, you might want to replace the fan. Hope this is useful.
Posted on Jan 19, 2010
Have a Samsung HLP6163wx problem
Hey friend:
most probably' 1) either your lamp was NOT installed correctly, or
2) lamp is bad - (it happened to me once, so no sweat!) - in this case you need to return the lamp in exchange for a new one.
Please watch any of the 'how to change the lamp on a dlp tv' video demo available on YouTube. Its not difficult. I already changed mine 3 or 4 times. Thanks
Jun 12, 2014 | Samsung HLN617W 61" Rear Projection HDTV
Where are the lamps located on the samsung HLP6163wx
The lamp is on the back of the TV.
Remove the little door or the back cover to get to the lamp.
Here is the link for the video showing you how to remove the lamp.
http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Good luck
www.aaatvservice.com
Sep 02, 2012 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP6163WX picture shuts off.
Likely the DMD unit which is part of the light engine--if have to unplug set the microprocessor is getting scrambled and cannot operate. Common and fatal issue as to replace the light engine the cost will exceed the value of this set---DMD can be purchased alone but costs almost as much as the whole engine that comes with it.
Seen several of these sets---a shame but even at wholesale the part to fix it makes it not worth fixing.
May 31, 2012 | Samsung HLP6163W 61" Rear Projection...
Chnaged the color wheel and lamp. stanby/temp and
YOU MAY STILL HAVE A BAD BALLAST OR POWER SUPPLY BOARD.Samsung recommends replacing the ballast and power supply board at the same time.
Jun 04, 2010 | Samsung HLP6163W 61" Rear Projection...
Hlp6163wx new color wheel new bulb new ballast still wont turn on just a black screen have sound but no picture then it says light then flashes the other green one then the red then powers off then tries...
The next item I would try is the SMPS power supply board. If it is not producing enough voltage, the ballast won't come on so the lamp will not turn on.
Apr 02, 2010 | Samsung HL-P6163W 61" TV
My TV turns off by itself. It is a Samsung HlP6163W. Service Model HLP6163WX/XAA. The two green lights flash at the same time. I think it is overheating the bulb. How do I fix it.
Lamps don't really last very long typically 1 to 3 years depending. You may just need to replace the lamp. A burner gap of a lamp expands as the lamp warms up. If the gap is too large due to age (normal usage) the lamp will fail to light or shut down once the expansion occurs. The solutions to either problem is to replace the lamp.
Mar 15, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung TX R3079WH
the stand by is the indication of a bad power supply. take your tv to w/shop,
even if a tv is on stand by a tone is heard when switching on a tv.
Apr 29, 2009 | Samsung Televison & Video
Samsung tv
as far as it turning off on its own I would get a fan on it and see if that make a difference make sure that the fan is able to flow around the tv especially through the back of it, if this stops it from turning off then it is an overheating problem
Mar 22, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HLP6163W 61" Rear Projection HDTV-Ready Television Logo
289 people viewed this question
Jerry Greenberg
Jerry Greenberg
