Question about Olevia LT42HVi 42 in. LCD Television
How to Remove the Base
I have set my Olevia 42 HDTV to a wall mount... How do I remove the base?
I have an Olevia 42" TV. I was able to remove the base by removing 16 screws on the back side. They were arranged vertically in 4 sets of 4. The screws go through the back panel, through the base and attach (without nuts) directly into the inside of the TV. After removing the 16 screws the stand simply slides out.
I tried removing two screws underneath the base area. They were small screws and were a pain to remove. I thought I would try that first instead of removing 16 screws but that did nothing.
Posted on Sep 07, 2010
The 2 screws on each side directly above the stand legs need to be removed. You do not need to remove the big plastic back panel. Remember the TV is heavy, the screws are under pressure and when the screws are removed the TV will drop. I suggest 3 people, 1 to remove the screws and 2 to hold up each side during and after the screws are removed.
If you want to remove the speakers, just disconnect the wires at the TV source, & remove top 2 screws from the brackets on each side of the centerline. Lower the speakers & rotate the bottom forward & out the front.
Posted on Jan 06, 2008
Did u remove the base yet ?
Posted on Jan 01, 2008
How do you remove the base from 42 INCH OLEVIA
on my tv (42 inch) there are sixteen screws on the middle set up in four rows of four each. these are about two or three inches long.
take these out and the base comes off.
hope this helps.
Jun 15, 2009 | Olevia LT42HVi 42 in. LCD Television
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remove base from tv?
How many screws did you remove? You should have eight, there are 2 screws along the bottom that are easy to miss. Make sure you check each hole with a flashlight just to make sure you got them all.
Jan 03, 2009 | Olevia LT42HVi 42 in. LCD Television
Trying to take the base off my son's 42 inch olevia 542-b12
There are 16 phillips head screws on the back of the TV above the base, remove all of them and the base just falls out.
Dec 31, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Remove Swivel Base on 42LB1DRA
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Good Luck.
Dec 30, 2007 | LG 42LC2D 42 in. LCD HDTV
Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Dec 25, 2007 | LG 42LC2D 42 in. LCD HDTV
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Olevia LT42HVi 42 in. LCD Television Logo
2,138 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
